wwwevecom
CAPsMAN Slowly turn on 5GHz band
Wed Jun 26, 2019 2:43 pm
Hello, I have 3 pieces cAP ac - RBcAPGi-5acD2nd with 2,4 and 5GHz wifi.
The problem is this: after factory settings works normally at 5785GHz, the two wifi adapters choose the frequency for 1-2 minutes.
But when working in CAPs MAN system and when set higher frequencies than 5280GHz I have to wait 15-20 minutes to react access point and start broadcasting SSID.
If I choose a low frequency 5180, 5200 or 5220 no problem, wifi adapter starts immediately broadcast SSID immediately
Where the problem might be?
muetzekoeln
Re: CAPsMAN Slowly turn on 5GHz band
Wed Jun 26, 2019 4:10 pm
Search for topics DFS and Radar detection.
mkx
Wed Jun 26, 2019 4:13 pm
Any channels between 5250 MHz and 5720 MHz (channels from 50 to 144, both included) are subject to DFS ... meaning that AP has to check that frequency sub-band is not used by some radar (air-control, weather or military) ... which takes some time.
wwwevecom
Thu Jun 27, 2019 10:47 am
Ok thank you.
Is there a way to speed up, for example skip DFS or save selected? Or or with another setting?
normis
Thu Jun 27, 2019 1:28 pm
Don't use frequencies that are used by radars, if you can.
See console command:
/interface wireless info country-info austria
Just use your own country name, and you will see which frequencies have "dfs" next to them.
mkx
Thu Jun 27, 2019 3:25 pm
It's illegal to skip DFS protocol and that one has to be performed on any channel which is declared to be DFS-infested (even if there's no radar signal present). As @Normis suggested, use channels which are not marked as DFS.
Users browsing this forum: Gadulowaty and 91 guests
