melvineris
Bridge VLAN performance drop
Tue Aug 06, 2019 10:20 am
I’m tinkering with the idea of creating some VLANs in my network, however after a simple activation of vlan-filtering on the bridge, my internet connection speed seems to drop by about 30% (as measured by speedtest.net).
My device is CRS326-24G-2S+RM, I’m using it as a router at the moment with all the ports under the same bridge interface.
How reliable is a speedtest.net test, or is there a better test I could perform? Is the performace drop to be expected? Why would activating vlan-filtering affect my WAN connection speed.
thanks
mkx
Re: Bridge VLAN performance drop
Sun Aug 18, 2019 11:30 am
CRS3xx should have HW offload support for VLANs ... if things are configured properly it should not experience any slowdowns in intra-VLAN frame forwarding.
You shoukd be aware that CRS devices are essentially switches and L3 (routing) performance is lagging far behind.
So whether the observed 30% performance drop you observed is expected or alarming really depends on configuration and expected performance. Hard to tell which as you didn't include any details in your post.
BR,
Metod
Users browsing this forum: No registered users and 23 guests
