miochoice
Signals BAD after latest upgrade
Fri Aug 09, 2019 1:16 pm
Any ide why my P2P signals went from 45/50 to 62/92?
normis
Re: Signals BAD after latest upgrade
Fri Aug 09, 2019 1:41 pm
Which device?
What circumstances?
What kind of client?
What config ?
miochoice
Fri Aug 09, 2019 1:50 pm
911G-5HPacD - Jirous dishes - 12 Km , 802.11, literally nothing was changed just did upgrade from 6.43.14 to latest OS and this happened , wanted to downgrade but cant even log into the far link, it is P2P link , same if i change for NV2
krafg
Sun Aug 11, 2019 8:14 am
I recommend to try with the latest versions of ROS and keep the last version that works good for you. If you can't login on remote device, you need to downgrade it physically.
Regards.
If you want to know my network, you can find it here.
flynno
Sun Aug 11, 2019 3:34 pm
It's possible that the antenna gain has changed on the radio to contry regulations reducing the power causing the signal to change. Did you upgrade both radios or just one?
InoX
Sun Aug 11, 2019 5:46 pm
Choose superchannel and no country for maximum power.
Users browsing this forum: No registered users and 15 guests
