geminisdemon
RBwAPG-5HacT2HnD + CAPsMAN + Rates config = 5Ghz network doesn't work
Wed Aug 14, 2019 4:53 pm
Hello everyone.
As the title says, when you set up a CAPsMAN profile for a RBwAPG-5HacT2HnD with custom Rates, it is impossible to connect to the 5Ghz network from an android phone. However with a laptop I was able to establish a connection, although the ping is quite bad, but I tried different android phones and it was not possible to establish the connection.
It is important to clarify that this only happens with the model RBwAPG-5HacT2HnD, I have the same configuration with other mikrotik APs for example RB962UiGS-5HacT2HnT and do not give any problem.
Best regards.
whatever
Re: RBwAPG-5HacT2HnD + CAPsMAN + Rates config = 5Ghz network doesn't work
Thu Aug 15, 2019 8:47 am
You have disabled all basic rates!? I don't think that is a good idea.
geminisdemon
Fri Aug 16, 2019 11:24 am
I've always found that configuration to work well for me.
andriys
Fri Aug 16, 2019 1:58 pm
That does not mean it is correct. Older devices (or older RouterOS versions) may have just silently ignore the invalid settings, that's why it worked (I'm just guessing here). Anyways, no client is supposed to be able to register to an AP if it cannot negotiate a supported set of basic rates. Disabling all basic rates essentially means making your AP unusable.
Users browsing this forum: No registered users and 24 guests
