2a3
upload speed down
Sat Aug 17, 2019 7:38 pm
hi
i use any service whit any speed. When I testing counnection with ps4, download speed fine but upload speed always constant at 69.3kbps and nat type 3 or fail. Why?
honzam
Re: upload speed down
Sat Aug 17, 2019 9:44 pm
How does it relate to Mikrotik?
2a3
Sun Aug 18, 2019 3:53 am
Via pppoe client on wlan interface .I use wireless service and radiolhg 5.
erlinden
Sun Aug 18, 2019 11:11 am
Can you please post a /export hide-sensitive?
Assuming this is a serious topic?
2a3
Mon Aug 19, 2019 11:08 am
hi
aug/19/2019 12:36:13 system,error,critical login failure for user admin from 192.168.88.254 via web
[admin@MikroTik] > export hide-sensitive
# aug/19/2019 12:37:03 by RouterOS 6.45.3
# software id = 3A9K-XBP7
# model = RouterBOARD LHG 5nD
# serial number = 7A6B0758450D
/interface wireless
set [ find default-name=wlan1 ] band=5ghz-a/n disabled=no frequency=5240 mode=station-bridge ssid=1009416CK62-ASIATECH-ESTAKHR-S2
/interface pppoe-client
add add-default-route=yes disabled=no interface=wlan1 name=pppoe-out1 use-peer-dns=yes user=9273204
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip hotspot profile
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp disabled=no interface=ether1 name=defconf
add comment=defconf interface=ether1 list=LAN
add comment=defconf interface=wlan1 list=WAN
add list=LAN
add address=192.168.88.1/24 comment=defconf interface=ether1 network=192.168.88.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid interface=wlan1
set allow-remote-requests=yes
/ip dns static
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new \
in-interface-list=WAN
/system clock
set time-zone-name=Asia/Tehran
/system routerboard settings
set auto-upgrade=yes
/tool mac-server
/tool mac-server mac-winbox
2a3
Mon Aug 19, 2019 11:34 am
one or more The router is reinstalled with netinstall !!
cdiedrich
Forum Veteran
Forum Veteran
Mon Aug 19, 2019 5:32 pm
The config looks good so far.
There's still a dhcp-client active on wlan1 - since you're using pppoe you won't need dhcp.
I can only think of a polarization and/or alignment issue here - check your signal levels, the rx levels on both chains should be pretty close, an imbalance of 6 or more dB is a sign of something odd going on there...
-Chris
2a3
Mon Aug 19, 2019 6:12 pm
-Chris
Users browsing this forum: No registered users and 57 guests
