I have a RB750Gr3 running as a router.
This has several VLANs on the LAN side, one of which is VLAN 10. This connects to a HP switch via a tagged port. I have another tagged port set up for the hAP AC2.
I've managed to configure the virtual AP (there will eventually be several SSIDs/VLANs) and clients will associate, but will not obtain a DHCP address from the DHCP server. The DHCP server is a Windows server running in VLAN 10 connected to the HP switch.
I've tried various configurations, but cannot make it work. Any suggestions on where I am going wrong?
I tried creating the VLANs on the ether2 interface and adding them to the existing bridge (with an IP address on the VLAN, I could connect to Webfig/Winbox from another machine on the VLAN.
Looking at forum posts and the WIki, I tried removing the VLANs and adding to the bridge, with the hAP AC2 mangement IP address in VLAN 10 assigned to the 2.4GHz radio interface. I could not connect to it in that configuration.
