Good day, please I want to know if the Mikrotik Router rb4011igs+5hacq2hnd-in can handle 80 concurrent wireless users....
Thanks.
I don't think this has to do with the number of users.Mine isn't stable enough. Frequently my 5hgz network goes away and I have to reboot the thing.
It all depends on on the kind of activity your users are doing ... if it’s just email and browsing without streaming and no real time activities then 80 concurrent wireless users should be easy to handle .... but if streaming and real time activities is part of the equation Then absolutely NO and under those circumstances perhaps 20 concurrent wireless users — The keyword is perhaps.Good day, please I want to know if the Mikrotik Router rb4011igs+5hacq2hnd-in can handle 80 concurrent wireless users....
Thanks.
It is obvious you do not know any of the device specs and obviously you have never used this model.but if streaming and real time activities is part of the equation Then absolutely NO and under those circumstances perhaps 20 concurrent wireless users
I have 2 clients with this model ... they purchased this device without my knowledge then called me to fix their poor decision. They no longer have this model.It is obvious you do not know any of the device specs and obviously you have never used this model.but if streaming and real time activities is part of the equation Then absolutely NO and under those circumstances perhaps 20 concurrent wireless users
It is a quad core 1.4Ghz with 1 GB of RAM that according to the test results in routing mode with 25 ip firewall filter rules and a packet size of 1518 Byte can reach almost 7Gbps speeds and about 300 Mbps for the smallest packet of 64Byte.
I guess because you could not solve the problem ! And because of that you consider this model as poor...they purchased this device without my knowledge then called me to fix their poor decision. They no longer have this model
Even @normis that is in Mikrotik Support said that this device can handle that number of users and more...
You just believe you know everything and you are the best...
Exactly, probably not. This means that will probably yes as well...!Will it work well, from the viewpoint of the clients? Probably not
No, I don't. Currently, I have 4 wireless clients attached to it.I don't think this has to do with the number of users.Mine isn't stable enough. Frequently my 5hgz network goes away and I have to reboot the thing.
Your ROS/firmware versions ?
*) wireless - improved IPQ4019, QCA9984, QCA9888 wireless interface stability;
What I expect to see:No, I don't. Currently, I have 4 wireless clients attached to it.I don't think this has to do with the number of users.Mine isn't stable enough. Frequently my 5hgz network goes away and I have to reboot the thing.
I'm running 6.46beta59 as it contains:
I'm hoping that Mikrotik can finally get the bugs worked out on this box.Code: Select all*) wireless - improved IPQ4019, QCA9984, QCA9888 wireless interface stability;
As of right now, I would never deploy this into any kind of production environment. The 5ghz wireless just up and disappears at least once a week.
schu
