tberg
60G 500M link
Wed Nov 20, 2019 8:45 pm
Installing our first 60G link. 500M link with a wAP AP on one end and LHG60 on the other. I'm wondering what we should expect for RSSI. I tried the Mikrotik wireless link calculator but don't see where it shows any signal levels. It just says the link status is reliable. We are getting -62 at the wAP and -68 on the LHG. Seems like it should be better than that. We are getting MCS 7 & 8, but it does go down in the rain.
server8
Re: 60G 500M link
Wed Nov 20, 2019 10:29 pm
500m better to use LHG both sides
mistry7
Re: 60G 500M link
Thu Nov 21, 2019 1:05 am
+1
Zacharias
Re: 60G 500M link
Thu Nov 21, 2019 10:18 am
WAP60 and LHG60 Have different radiation patterns and they do no work in the same way.
So yes, use the same model on both sides.
tberg
Re: 60G 500M link
Thu Nov 21, 2019 4:52 pm
I can see using same on both side for P2P, but if you're doing multipoint and need to go more than 200M you would want the larger gain on the client end. Maybe shouldn't use Mikrotik for any multipoint? That's part of what we're trying to learn.
This link is just a backup and we wanted to test multipoint operation over time. It turns out is was more reliable than I thought. One of the outages was our guys moving the radio and the other was a major storm with over 1 inch of rain per hour. Prior to that it hadn't gone down at all in 3 months, although we haven't had really heavy rains. That being said, I agree it seems 500 meters is a little too far for multipoint with Mikrotik at the moment.
Zacharias
Re: 60G 500M link
Thu Nov 21, 2019 5:51 pm
500m is nothing and MikroTik gives great solutions as long as you know what you do...
It is part of the network engineer to choose the correct equipment for its PTMP or PTP link.
tberg
Re: 60G 500M link
Fri Nov 22, 2019 3:58 am
I agree, and often the best way to know what to do as an engineer is test for yourself.
I guess I don't understand your statement that you should use the same on both ends because they have different radiation patterns. What do you mean by that? I know they have very different antenna patterns. I can understand that you need more link budget for that distance so use higher gain device on both ends.
Zacharias
Re: 60G 500M link
Fri Nov 22, 2019 9:43 am
You can see the physical properties of each antenna in the following link :
https://wiki.mikrotik.com/wiki/Manual:Interface/W60G
Users browsing this forum: No registered users and 40 guests
