vrsho
LHG 5AC link throughput
Fri Nov 22, 2019 10:52 am
i have a link with two LHG 5AC antennas and i cannot get max TCP throughput more than ~210mbit.
First antenna:
Second antenna:
Bandwidth test(Between 2 RB3011, LHGs are in bridge):
Am i doing something wrong? I thought i will get 300-350Mbit TCP in one direciton at least.
mistry7
Re: LHG 5AC link throughput
Fri Nov 22, 2019 11:08 am
How long is this distance?
If it is under 800m you better user 60G
vrsho
Fri Nov 22, 2019 11:12 am
Distance is 1km. I thinked about buying the LHG60 but my City is very Foggy and Rainy.
mfr476
Fri Nov 22, 2019 2:37 pm
In Mikrotik wireless is normal. I've been stating the problem in the forum for a year and Mikrotik says that I use old protocols but they don't tell me what the new protocol is or give me a solution. What really happens is a programming problem that they don't recognize or solve
vrsho
Sat Nov 23, 2019 2:48 pm
And no solution from Mikrotik?
mistry7
Sat Nov 23, 2019 3:48 pm
@Normis
In Mikrotik´s world, they say everything is working fine..
@vrsho
what does you mean ??
vrsho
Wed Dec 04, 2019 1:44 pm
What about routeros v7? Are there any improvements?
r00t
Wed Dec 04, 2019 2:03 pm
currently ROS 7 still uses same wifi radio driver as 6.xx so there is no difference
vrsho
Tue Mar 10, 2020 5:22 pm
Are there any news? :/
allstarcomps
Thu Mar 12, 2020 12:51 am
Use a larger router 4011s for be tests
May also try Ceee for the wireless.
Users browsing this forum: mbrmik and 26 guests
