MUM Europe 2020
muhamad90
2km link clear view i need your suggestions
Fri Nov 29, 2019 8:11 pm
hi
i wanna link 2 km link with clear view
using RBLHG-60AD
does it enough with 350mgbs download stable?
or i should change the device,,
mistry7
Re: 2km link clear view i need your suggestions
Fri Nov 29, 2019 8:46 pm
You will geht Full Speed with Perfect allignment
But you will loose Connection with every rain
Zacharias
Fri Nov 29, 2019 10:30 pm
Well 2km is a little too much...the max is about 1.5 km
@mistry7 why you say the connection will be so bad in rainy conditions ?
muhamad90
Fri Nov 29, 2019 10:51 pm
so what should i chose ? do you have recommendation ?
mistry7
Fri Nov 29, 2019 10:55 pm
We have several links at this distance, we are rain area g, depends on region he will loose connection on every rain.
Most times only couple of seconds but the connection drops.
muhamad90
Fri Nov 29, 2019 10:57 pm
mistry7
Mon Dec 02, 2019 12:13 am
Would it be a Problem to lose Connection for some seconds when it rains? If not, LHG60G is Good option
helipos
Mon Dec 02, 2019 1:02 am
RBSXTsqG-5acD
Assuming you just want a point to point link.
mistry7
Mon Dec 02, 2019 8:23 am
RBSXTsqG-5acD
350 MBit stable with SXTsq over 2km? Goog luck
server8
Mon Dec 02, 2019 8:45 am
Sad to say but for 2 km link i s better to use airfiber 5hd form ubiquiti
Zacharias
Mon Dec 02, 2019 3:25 pm
:shock:
Users browsing this forum: No registered users and 8 guests
