MUM Europe 2020
milad7
Very low performance with omniTIK 5 ac and SXT Lite5
Tue Dec 03, 2019 12:06 am
Hi guys
I have an omniTIK 5 ac and two SXT Lite5 and I'm going to set up the PTMP scenario.
Omnitik is installed in HQ and SXTs in branches.
Distances between the HQ office and branches are 70 and 170 meters. I could install one link so far which has awful CCQ and Tx/RX strength.
you can see the status as attached, current throughput is very low!!!!!!!!!
would you please help me to increase the performance?
Rudolfs
Re: Very low performance with omniTIK 5 ac and SXT Lite5
Tue Dec 03, 2019 10:54 am
Try enabling 5Ghz-a/n band in wireless settings if you are using SXT Lite5 on the other side. If the issue with low throughput still remains, I recommend generating supout.rif files on the AP and on one or both station devices and send them to support@mikrotik.com
https://wiki.mikrotik.com/wiki/Manual:S ... utput_File
quackyo
Tue Dec 03, 2019 11:01 am
Bad signal. Increase signal is the only answer.
Do this by removing obstacles, interference (change channel?), raise one or both end of the links higher, and possibly dump the omni in the middle and use something at least partly directional.
mkx
Tue Dec 03, 2019 11:16 am
In particular bad signal on Ch0 ... either Ch0 antenna is (semi-)defunct or there's some obstacle in the Fresnel zone which has polarizing properties and affect one polarity much more than the other.
BR,
Metod
milad7
Wed Dec 04, 2019 12:58 am
thanks for reply
I sent two support files to above email address.
awaiting for response
Users browsing this forum: No registered users and 18 guests
