in my home I have to Mikrotik APs installed, one HAP AC, which is connected to the physical LAN and one HAP AC lite, which is connected via wireless bridge to the HAP AC. (manual configuration, no capsman manager)
For the wireless bridge (VLAN-trunk mode) I use the 5GHz-Channels (wlan2) and the wlan1 I use for three WifiNetworks (one SSID on wlan1 and two virtual AP’s)
Never had any issues with the above mentioned configuration in the past, but since I installed additional devices (Sonoff T1EU2CH flashed with tasmota) my WIFI drives my crazy.
At first I installed only one of those devices and there wasn’t any issues therefore I ordered 3 additional to automate my roller shutters.
After some time (x-minutes until approx. 6h) the devices couldn’t be reached with the static ip addresses, but on the AP they are still listed in the registration tab (winbox). When I am going to kick the device from the AP it will reconnect and it will be pingable again. I do not really believe that this happens because of a bad network coverage, because one device is only few meters away from the AP.
Already tried some settings to get rid of this issue, but unfortunately no actions solved the issue:
1. Disabled one AP (turned off)
2. reduced the TelePeriod (Communication period) of one sonoff device (from 300s to 29s)
3. Set some special wifi options on one of the devices
SetOption56 to ON
SetOption57 to ON
Do you have any hints for me?
Thanks in advance!
BR
Michael
