WeWiNet
LTE CAT6 modem disconnecting every 2-3 minutes
Wed Dec 18, 2019 12:51 am
my LTE CAT6 modem does disconnect every 2-3 minutes.
Can't see why this should happen. (SIM card works fine in mobile phone, same APN setup as well).
And it worked in the past on leap-mini without any issues.
23:09:22 lte,info WAN2-LTE: registered home
23:09:29 interface,info WAN2-LTE link up
23:11:04 lte,info WAN2-LTE: not registred, state: 0
23:12:04 lte,error failed to register on network
23:12:04 lte,account WAN2-LTE session: 155s 9158316/263300 bytes 8608/3405 packets
23:12:04 interface,info WAN2-LTE link down
23:12:11 lte,info WAN2-LTE: registered home
23:12:18 interface,info WAN2-LTE link up
23:14:20 lte,info WAN2-LTE: not registred, state: 0
23:15:20 lte,error failed to register on network
23:15:20 lte,account WAN2-LTE session: 181s 24826400/659577 bytes 22939/8566 packets
23:15:20 interface,info WAN2-LTE link down
23:15:27 lte,info WAN2-LTE: registered home
23:15:34 interface,info WAN2-LTE link up
23:16:06 lte,info WAN2-LTE: not registred, state: 0
23:17:06 lte,error failed to register on network
23:17:06 lte,account WAN2-LTE session: 92s 3397383/74285 bytes 3117/998 packets
23:17:06 interface,info WAN2-LTE link down
23:17:13 lte,info WAN2-LTE: registered home
23:17:20 interface,info WAN2-LTE link up
23:18:45 lte,info WAN2-LTE: not registred, state: 0
23:19:45 lte,error failed to register on network
23:19:45 lte,account WAN2-LTE session: 145s 39661952/778303 bytes 36336/10617 packets
23:19:45 interface,info WAN2-LTE link down
23:19:52 lte,info WAN2-LTE: registered home
23:19:59 interface,info WAN2-LTE link up
WeWiNet
MTCNA
I like a new challenge, I migrate to ROS7... :? or maybe I am just crazy :lol: !!!
SiB
Re: LTE CAT6 modem disconnecting every 2-3 minutes
Wed Dec 18, 2019 1:36 am
paste:
[admin@MikroTik] > interface lte export
Try this:
interface lte set lte1 allow-roaming=no band="" modem-init="" network-mode=lte operator=""
interface lte at-chat lte1 input="AT*Cell=0"
Good idea is enable logging:
/system logging action
add memory-lines=10000 name=test target=memory
/system logging
add action=test prefix=SXTR__LTE topics=lte
add action=test prefix=SXTR__GSM topics=gsm
MTCNA + MTCRE + MTCINE | ~600 users at ~150 RouterBoards in EMEA | Telegram: @SiB_PL
WinBox Tip: F6 works as ALT+TAB | Gliffy.com - free network schematic | prnt.sc - free ScreenShot software
I back from vacation and try answer at LTE posts
WeWiNet
Thu Dec 19, 2019 12:24 pm
Hi SiB,
thanks for the advice. Strangely enough with your first command (the second one fails) the modem is now connected
without disconnection.
Thanks for that. I still need to test at night time, when load in my area increases a lot.
PS: When the failure appeared, the LTE1 status was: Rx/TX disabled, not searching. Why would the LTE interface not search for network?
I could understand that the network drops the connection, but the modem should always search and RF (Rx/TX) should always be enabled.
Seems to me like the module had some internal reset or so...?
WeWiNet
MTCNA
SiB
Thu Dec 19, 2019 12:35 pm
What mens "Rx/TX disabled"? lte1 as interface can be disabled but Rx/Tx can have =0 or >0.
If you just have enable 3g/lte then he drops to 3g and stay on it.
He try stay in LTE if you not use Cell Lock. I check on 3 ISP sim card's and he always try reconnect. (I put my SXTR&LTE6 on floor, even into metal box :) ) and after put it on place with signal the connectivity comeback to lte (in lte only mode) or 3g (if 3g.lte mode was selected before).
I know about issue with Rx=0, rsrq=19,5dB, other signal value freez what I currently checking with support@mikrotik.com and decsribe it into: viewtopic.php?f=21&t=154848#p765554 but this is only when you use Cell Lock feature.
One bonus.
When i select Band=3 and CellLock (the same cell have 3g and lte) then when LTE is out-of-signal then 3g starts works for ever, never comeback to lte mode by himself. This works at CellLock with specific Band, and then the info give me earfcn&phy-cell on 3g connection what is never show in just simple 3g connection.
I hope my answer is ok :)
WeWiNet
Fri Dec 20, 2019 12:16 am
Hi SiB
this is the error I get when the LTE link goes down and I don't understand why this happens
nor what it means.
Any idea?
WeWiNet
MTCNA
SiB
Fri Dec 20, 2019 1:32 pm
Hmm, I know only one situation todo this.
When I do CellLock at CellID with weak signal then this will happens.
Try do:
/interface lte at-chat lte1 input="AT*CELL=0"
/interface lte at-chat lte1 input="AT+RESET"
and check again.
Give me a feedback, please.
Please check your signal, maybe you are at "black hole" and time to change ISP or test other one?
Mizm
Sat Dec 21, 2019 4:22 am
also face stability problems with my new R11e-LTE6, in my case whole modem randomly hang, "AT+RESET" cmd from your post helped for now
signal is perfect, because im <50m from BTS
wAP ac+R11e-LTE6, RB3011, cAP
WeWiNet
Sun Dec 22, 2019 10:20 am
Issueing:
Gives following error :
output: +CME ERROR: phone failure
and even reset command returns:
output: ERROR
I opened the audience and think I could probably try to replace the modem with a different one.
Do you know what other vendor module would work (It probably uses USB connection)?
WeWiNet
MTCNA
Setneuf
Fri Dec 27, 2019 1:49 am
I have a even stranger problem, the modem connects to my operator (NOS in Portugal), everything works fine, BUT! I have no Internet connection, the Mtik while doing a ping it shows the status TIMEOUT, I can see the TX working but no RX.
Plug a SIM card from another operator and boom, everything is ok... wtH?!?
I've already tried changing MTU, other things that I don't remember now, but the stupidity of all of this is that if I change from LTE to 3G I get Internet.... :evil:
Same SIM in a Huawei B something works perfectly... Does anybody knows what the hell is going one here?
PS: The LTE Cat4 modem works fine with tha F...... SIM card....
Thanks for your time :lol:
Working with Mikrotik since 2007
uldise
Fri Dec 27, 2019 4:26 pm
you are at very cell edge, aren't you?
uldis
Mon Dec 30, 2019 4:01 pm
WeWiNet, please write to support@mikrotik.com with the description of your problem. If I understand that you don't have any CellLock command used - just regular configuration?
Setneuf, it looks like the signal might be too low for the Band20 LTE. What signal you were getting with the regular LTE card and was it using the same band and cell?
When you switch to 3G it could switch to different tower. Try to use LTE and disable the Band20 and check only band 1,3,7,8 and check if it finds any connection.
You can try to check the nearest LTE tower in the cellmapper.net site to see which bands each tower supports (those are user data and might not have all the new data, you can also try to contribute your date if you have Android phone from your Region if you have the same LTE operator SIM card).
SiB
Thu Jan 02, 2020 4:24 am
WeWiNet
output: ERROR
I cannot reproduce this behavior.
I can only get response like "no such item" or "failure: modem not ready" etc. but at+reset or at*cell=0 give me some proper responce.
Remember to provide more information like:
put [interface lte info lte1 once as-value ]
interface lte print detail
interface lte apn print detail
You should write to support@mikrotik.com with attachment supout.rif file.
I think the best is this one in Cat.6 and the same 2xCA:
Quectel EP06-E and wAP R ac (RBwAPGR-5HacD2HnD) -> viewtopic.php?f=3&t=150368
SiB
Thu Jan 02, 2020 4:35 am
Mizm
On hand you means Freeze ? IP address still assigned + lte1 up and running + Rx=0 + status signal not change at all like constans ?
Please read this: viewtopic.php?f=21&t=154848#p765554 Similar?
You use just normal (without CellLock)?
You enable lte topic in logging and discover someting?
Please provide:
SiB
Thu Jan 02, 2020 4:59 am
Setneuf
You not use a Cell Lock by at-chat lte1 input="at*cell=2,3,,6400,143" ? Because in CellLock after loose signal at moment you stuck in offline mode. Maybe you assign only B20 or this is your only Band with signal?
In normal mode means at-chat lte1 input="at*cell=0" works me automatic migration into 3G (UMTS/HSDPA..)
I can confirm that different SIM cards works me different too.
CellLock at one ISP works with Cameback signal.
Other ISP SIM card works on R11e-LTE6 and USB E3372 and many devices like phones but not work in first version "SXT LTE 3-7".
At screen I see similar situation to my report viewtopic.php?f=21&t=154848#p765554
It's like you do CellLock at 3G... OR you select that Band who works you only at 3G.
Please do:
# wait to new connection
# wait longer because lte1 will disapeer from device
system routerboard usb power-reset
system resource irq print interval=1s where users~"usb1"
# COUNT is still upper?
In general this is bad re-connecting stuff from MikroTik and we all try send own supout.rif to support@mikrotik.com to produce better modem firmware who give us good stability, proper 2xCA and after long signal-off situation automatic registration in network and connection without own scripting.
SiB
Fri Jan 03, 2020 9:38 pm
WeWiNet
You must enable the AT logs by
/system logging
do reboot of mikrotik to have got fresh situation.
Next please share log's or check the AT+CFUN.
CFUN=4 means "disable phone both transmit and receive RF circuits"
ROS send the AT+CFUN=1 to activate full functionality but before that do stuff like setup PIN, BAND's etc.
Remember that if device not work properly by out-of-box then you can give it to warranty.
Setneuf
Sun Jan 05, 2020 11:36 am
Setneuf
Please do:
Hi again, tried only one band and nothing... I'm getting very dissapointed with this modem, is even worst than the r11e-lte... :-x
The modem connects, but no internet or anything come in from the provider.
SiB
Sun Jan 05, 2020 12:58 pm
Setneuf
Your screenshot give confirmation that you have got IP address from your ISP, connections is proper.
Show us this:
/ip address print  <- should print IP 83.132.25.126 at lte1 interface
/ip route print    <- should print "ADS 0.0.0.0/0 via lte1"
/interface lte apn print   <- should print "add-default-route=yes"
Means you must have in APN a add default route to yes or just a manualy route to 0.0.0.0/0 via gateway=lte1.
And then you could do ping/tracert etc to internet.
Without default route via lte1 interface you not reach internet. Your screenshot show only 1/2 necessary stuff.
You just now write that you cannot RUN a internet. I thinking that it's working and you must do sometimes a reboot etc. to do re-connection. Or you setup some parameters who block you a connection but you have a primary start setup problem.
WeWiNet
Mon Jan 06, 2020 10:39 am
I did not use the LTE modem for a while, but today when trying to use it my Audience CAT 6 modem is just completely stuck!!!
It toggles every 10 seconds the message in status: "tx and rc rf disabled" --> full --> "tx and rc rf disabled" --> full
Using same setup as always, nothing changed (same APN etc.). No cell lock used or anything like that.
Here the log that shows up:
09:19:35 lte,async WAN2-LTE: rcvd +CPIN: READY
09:19:35 lte,async WAN2-LTE: sent AT*BAND?
09:19:35 lte,async WAN2-LTE: rcvd *BAND: 11, 78, 147, 480, 50923735, 0, 2, 2, 0
09:19:35 lte,async WAN2-LTE: sent AT*BAND=11,78,147,480,50923735,0,2,0
09:19:35 lte,async WAN2-LTE: rcvd OK
09:19:35 lte,async WAN2-LTE: sent AT*lteband=3,7,1,20,12,17,2,25,26,5,8,38,41,40,39
09:19:36 lte,async WAN2-LTE: rcvd OK
09:19:37 lte,async WAN2-LTE: sent AT+ZGDCONT=5,"IP","sl2sfr",0
09:19:41 lte,async WAN2-LTE: rcvd +CME ERROR: Invalid Param
09:19:41 lte,async WAN2-LTE: sent AT+ZGPCOAUTH=5,"","",0
09:19:45 lte,async WAN2-LTE: rcvd +CME ERROR: Invalid Param
09:19:45 lte,async WAN2-LTE: sent AT+COPS=0
09:19:45 lte,async WAN2-LTE: rcvd OK
09:19:45 lte,async WAN2-LTE: sent AT+COPS=3,0
09:19:45 lte,async WAN2-LTE: sent AT+CFUN=1
09:19:45 lte,async,event +CPAS: 2
09:19:45 lte,debug WAN2-LTE: config ok
09:19:45 lte,async WAN2-LTE: sent AT+CFUN=4
09:19:45 lte,async,event *RADIOPOWER: 1
09:19:45 lte,async,event +CGEV: ME DETACH
09:19:45 lte,async,event +CPAS: 5
09:19:45 lte,async WAN2-LTE: sent AT+CPMS="SM","SM","SM"
09:19:45 lte,async,event *RADIOPOWER: 0
09:19:45 lte,async WAN2-LTE: rcvd +CPMS: 7,30,7,30,7,30
09:19:45 lte,async,raw WAN2-LTE: sent AT+CFUN?
WeWiNet
MTCNA
SiB
Mon Jan 06, 2020 3:57 pm
WeWiNet
In my opinion the WARRANTY needed. You can do supout.rif and ask the support@mikrotik.com for confirmation.
Your R11e-LTE6 is inside PCB, not separate modem in mPCIe slot - info from photos at mikrotik.com - means only warranty.
What is super wrong here.
The APN "sl2sfr" I assume is correct, you can try write wrong and check what will change in logs but the error about invalid param's are wrong. Syntax is proper. Maybe the MTK support can know what generate that error but it's not your error I think. Realy, please contact with support because it's not problem to solve at forum.
I cannot give more info because all my ISP do correction of APN and even if I write "WrongAPN4884" then they are accept anythink as default "internet" but when I type specific like "internet.cp" then my ISP only at this APN give me a PublicIP. As you can see I cannot in my country write wrong apn and check what is normal response but the invalid syntax is like some other problem.
The CFUN=1 or CFUN=4 is normal and this give you this two state. Problem before is with APN syntax.
Please write to support@mikrotik.com
WeWiNet
Mon Jan 06, 2020 4:20 pm
SIB,
thanks for your advice.
I think I found my problem (hopefully).
Initial boot of LTE modem must complete once!!! (don't disrupt it)
When you do it correctly and then disable modem, I get good status:
"Not Searching"
"Pin ok"
Functionality: "minimum".
If I then need LTE modem I can enable it and it works!!!
Before I had after reset/power cycle, DSL and LTE i/f up and each try to get up. But DSL netwatch was disabling
LTE very shortly after boot (I think this was too early).
Now I added delay: I let LTE come up completly once after boot, and only then disable it...
I will try to test couple of times in coming days to see if this was really my issue.
If this is confirmed it would mean ROS to LTE modem communication is not robust enough and you need to gracefully disable LTE modem
(but I could be wrong ;-))
WeWiNet
MTCNA
SiB
Mon Jan 06, 2020 5:52 pm
WeWiNet
Yes, I not know you script you have but the any startup stuff must have got some delay.
Even the /system reset-configuration run-after-reset=WithDelay.rsc must have added delay like 20s because it's not work. Means every export to file not will be works here as out-of-box and the "delay 20" must be added at first.
I see post's at forum when the "/interface lte set lte1 modem-init=" is not used and MikroTik employe give info to add scheduler with delay.
This is another good tip to have in memory. I hope this was a real problem here. Good Luck.
WeWiNet
Tue Jan 07, 2020 10:07 am
Hi SIB,
I confirm for now, with LTE interface delay, my router continues to work correctly.
But I think it is not correct to depend on the user to foresee delay (how much???) when switching on/off an interface:
Example in my case:
- Netwatch starts at boot (but when???)
- In boot script I disable first thing the netwatch script (but when???).
Guess what happens? --> Boot script runs before or after netwatch is configured and therefore either I can't disable it really
or Netwatch already brought up LTE...
In my case Netwatch starts to work (I see the log) and then stops luckily before LTE went up... not a clean way to do things.
I have a workaround now but think ROS should take care of boot times/status of external modules (within the product) without having
user to add arbitrary delays...!
WeWiNet
MTCNA
mkx
Tue Jan 07, 2020 11:09 am
The good (or in this particular case: bad) thing about ROS is that it's completely open for everybody to adapt it according to their needs. So it's mighty hard to foresee everything in advance to make systematic work-arounds.
For example: netwatch is a generic command that checks L3 connectivity. It doesn't have any fine tuning parameters (such as defining route towards test target) and it relies on general router setup (which is mostly fine, but I can think of cases when one would prefer to have more control). Ditto for up/down actions, they are normal scripts. And I can imagine that not all interfaces are equal. For example, an ethernet interface with static IP set can be up and running within milliseconds after both ends enable their interfaces.
Broadband modems are on the other extreme end regarding startup time ... some time is taken by modem initialization (and it largely depends on modem type), some more time is taken by modem to find and register to mobile network ... this depends a lot on modem settings and on mobile network as a whole. Then it comes to data link establishment (in legacy technologies this is a separate operation and takes some time to authenticate user in MNO's core network while in LTE this is usually part of registration procedure). Which means that script which performs action on LTE modem should take these peculiarities into account ... e.g. skip the action on host down if ROS uptime is less than say 1 minute or delay script termination by 30 seconds after modem is being reset or something like this.
BR,
Metod
SiB
Tue Jan 07, 2020 11:21 am
Hi SIB,
Example in my case:
I have many scripts/schedulers but any of them are not interference that way to r11e-lte6 stops working properly. I don't understand what your script can execute who will be that mess.
My netwatch have got 10s interval and even is down-script have got at+reset then still works fine.
You can do few stuff.
Check when netwatch/scheduler start working - you can add line to generate a blue log entry to see every running of script in logs..
log warning ("UPTIME: ".[/system resource get uptime ])
You can add at start of any script just exiting is uptime is not 5m by:
local uptime [/system resource get uptime ]; if ($uptime < 5m) do={:error "Not now" };
Write it to support@mikrotik.com
WeWiNet
Wed Jan 08, 2020 6:54 pm
Hi SIB,
Today I had again a couple of link downs after 25 minutes good LTE connection with the modem
stuck on same problem as I described earlier (not using any cell lock or so).
So my "workaround" did not really solves the issue.
I might need to move back to my RB4011 and use external LTE router!!!
WeWiNet
MTCNA
SiB
Wed Jan 08, 2020 8:04 pm
WeWiNet
Hi SIB,
Summary:
#1 you show some lte logs but not all and I write you to enable full logs and lte export in #2 - you not provide this.
#3+#5 you write about "Rx/TX disabled, not searching"
like in Cell/Freq Lock with bad settings.
#8 you write that "AT*CELL=0" give you "+CME ERROR: phone failure" or even "output: ERROR"
This is total bad like you have different modem from r11e-[ lte | lte6 ] but you still not provide full info or export of configuration.
I never see this on my r11e-lte6.
#11 Support of MikroTik write you to send them description to support@mikrotik.com
but you not write about this.
#12 I write you to give "info lte1", prints from cli. Give you alternative modem on your request.
#15 I write you again request about logs and give hint that +CFUN is responsible about modem functionality mode.
#18 LOGs !!! with wrongs AT answers on common commends. Too strange and I write about warranty.
#20 You write about some start-up scripts but you not provide any export etc.
Now:
I still assume that your signature means we speak about ltap-mini but with what modem? I still don't know, because it can be buy without it and modem can be added. Modem version's US/4G/LTE/LTE6 works differ.
Maybe you works on old v6.x version and never do a modem upgrade by " interface lte firmware-upgrade lte1".
Maybe the at*cell is not proper for your and before error's are normal.
Still the errors #18 should work and if all this is not releated with ISP or just SIM card then you should use a warranty and write to support@mikrotik.com long ago. They can install you a new releace candidate modem firmware v22, check logs from supout.rif or from your device etc. Realy. Without checking your export to finding kill-herself behavior in scripts/netwatch/etc. and bad doings the MTK Support can recommend you write RMA.
In my possition of regular user who read manual and can use google to do additional searching I can write you in my opinion new firmware or warranty are your way to solve your case.
Some person's write me PM into links from my signature and we do remote assistance with call. Firmware/Warranty is your way or bad configuration with scheduler who do every 2m the usb power-reset.
I hope you learn someting from my answers.
BR Marcin
WeWiNet
Thu Jan 09, 2020 8:29 pm
Hi Marcin,
I highly appreciate your effort to help me debug my setup!
For instance I was not aware of the delay you can add with "uptime", which helps me for other things as well!
Therefore thank you for all your good advice. You are for me Mr. LTE!!!
Right now I can't and don't want to spent much more time on debugging it.
It works so-so which is for now enough (and I like the Audience for the rest of its Wifi functionality).
For completeness my config below. As you see it is as basic as it could be. When I drop my SIM card in an ASKEY LTE router,
a Laptop with 3G modem etc it always "just works", (and in general gives me higher data rates than the LTE11-CAT6 modem).
/interface lte export
/interface lte apn
add apn=my-apn name="My-APN-Name"
/interface lte
set [ find ] apn-profiles="My-APN-Name" mac-address=xx:xx:xx:xx:xx:xx mtu=1480 name=\
    WAN2-LTE network-mode=3g,lte
Subject closed :-)
PS: If I go to Prague, I pay you a beer, how about that ?
WeWiNet
MTCNA
SiB
Thu Jan 09, 2020 9:15 pm
WeWiNet
Subject closed :-)
Beer Accepted, I will be in Prague and I just create a t-shirt with my avatar and footer/signature on it. Beer connecting ppl :)
OlofL
Mon Jul 13, 2020 10:50 am
I have this issue on the new Mikrotik LTE Audience.
  • I have upgraded to latest lte modem firmeware.
    I have tested all different routerboard software (testing/beta/stable)
    Upgraded routerboard firmware.
I can reproduce this issue with LTE disconnecting by just starting a simple speedtest.
Any news on a working workaround, or is it a hardware bug? I have another Mikrotik Chateu LTE router, and it is working just fine...
SiB
Mon Jul 13, 2020 1:33 pm
Watch LTE parameters: viewtopic.php?f=7&t=153622&hilit=watchdog#p768105
Enable logs: /system logging add topics=lte
with this you can see when and how often the cell/tower will be change - this should be start point for you.
spartan
Thu Dec 17, 2020 3:06 pm
Good afternoon. I have a similar problem. Yesterday i installed a new Mikrotik RBwAPGR-5HacD2HnD, Ros version 6.47.8, modem firmware version R11e-LTE6_V026. Approximately every 60-120 minutes, the connection breaks "failed to register on network". Is this a common problem with this modem or is there already a solution?
https://prnt.sc/w4r6t9
SiB
Fri Dec 18, 2020 12:44 am
That behavior is know from few problems and you have enabled logs but not show all who do breake.
You should show logs from before brakes happend, only some lines give me a clue....
Please public the result of:
/log print file=log.txt
You can search if you have got a error just after SIMDETECT=2,NOP - if yes then this is solved in new firmware. Then please write to support@mikrotik.com or https://mikrotik.com/support
islamlaipanov
Sun Jan 03, 2021 10:31 pm
Hi! I have exactly the same problem with my lhg lte6 kit. Modem disconnects every 30-40 minutes with "failed to register on network". firmware R11e-LTE6_V026, ros 6.48
log screenshots are here https://prnt.sc/wfhk50, https://prnt.sc/wfhknh
islamlaipanov
Wed Jan 06, 2021 7:14 pm
any help here? I really have no idea with that. I've found a similar problem viewtopic.php?f=13&t=171251&p=837995#p837207
killersoft
Thu Jan 07, 2021 4:29 am
I heard 2 things to try.
1. is to bulk up your sim card with some tape at the back of it to ensure its pushing up against the pins, as apparently some sim's are thinner than the specification
2. There is a beta v027(as of Jan2021) that mikrotik can send you. They will also ask you to put the current LONG-TERM RoS on your device with that update too.
Ensure your power supply can supply the amperage too. !
Whats your signal levels too when its is runnings ?
MTCNA
MIT, BIT,CERT IV Electronics.
ITIL
spartan
Fri Jan 15, 2021 12:43 pm
Tech support Mikrotik recommended me to stick tape on the back of the SIM card. So-so solution, did not try. With the SIM card of another operator, there were no breaks, the thickness is the same. As a result, we decided to take the Mikrotik to the store, and instead buy a regular router, which was sold by the telecom operator itself. With their router, everything works stably, while it is 3 times cheaper. For the home, this router is enough with the head, users are happy. I came to the conclusion that the problem is a conflict between the equipment or networks of a particular provider and the Mikrotic modem. In this case, we decided not to go too deep into the reasons and replaced the router. I have already installed several hundred Mikrotiks of various models and never had any problems.
Users browsing this forum: Baidu [Spider] and 67 guests
