jenya
60GHz products, narrower channels than 2Ghz?
Thu Jan 09, 2020 2:58 pm
Simple question: Why Mikrotik 60GHz products cannot use narrower channels than 2160MHz?
mistry7
Re: 60GHz products, narrower channels than 2Ghz?
Thu Jan 09, 2020 3:05 pm
This is requested from the beginning.......
1. chipset doesn’t support it
2. development is needed = would take years...
jenya
Thu Jan 09, 2020 3:35 pm
Why Metrolinq can ? (Half Channel support)
https://support.ignitenet.com/portal/kb ... e#241-4004
normis
Thu Jan 09, 2020 4:14 pm
Different price class, different hardware
jenya
Thu Jan 09, 2020 11:11 pm
With this hardware is it sure it won't be possible in the future?
And one more - when will be available Cube Lite60 with gigabit ethernet?
Thanks a lot
mistry7
Fri Jan 10, 2020 9:04 am
Thanks a lot
Wait for X-Mas........
Look around, there are some solutions with smaller Channel available.
And some with 5 Ghz Backup coming up....
jenya
Fri Jan 10, 2020 12:03 pm
Thanks a lot
Can you be more specific? What 60 ghz device with a smaller channel?
If you don't want to mention it publicly send it to jenya@seznam.cz
marekm
Fri Jan 10, 2020 12:13 pm
What about more than 8 stations per sector? Especially the 180deg sector (wAP60Gx3). Is it just an arbitrary limit set by firmware, or some real hardware limit?
I would not complain about 100Mb ports in Lite60 if it was possible to connect 80 (not 8 ) of them. Then I would need no reverse-PoE switches to share LHG60's.
If this max 8 limit is due to CSMA/collisions - make a good TDMA/polling protocol.
mkx
Fri Jan 10, 2020 5:56 pm
Thanks a lot
@mistry7 is just being sarcastic ...
Users browsing this forum: No registered users and 60 guests
