MUM Europe 2020
XioneG
WiFi Settings Contry Belarus not found. Russia3?
Fri Feb 14, 2020 1:23 am
Hello.
There was a problem in the device setup
Can't set the correct Country
How can it be changed now for Belarus? :?
Device: Mikrotik RB4011iGS+5HacQ2HnD-IN
RouterOS: v6.46.3
XioneG
Re: WiFi Settings Contry Belarus not found. Russia3?  [SOLVED]
Fri Feb 14, 2020 2:53 am
Solved
Netinstall solved the problem.
Thanks. :D
normis
Fri Feb 14, 2020 9:11 am
You should buy devices in your region to avoid such problems in the future. The seller has also done some things he shouldn't have.
Users browsing this forum: No registered users and 27 guests
