ilja
Super slow WiFi speed on default configuration
Sat Feb 22, 2020 1:19 pm
Hey all.
Can please someone help me understand what could be the problem in my simple configuration, when my WiFi is incredibly slow?
Came to a point of replacing home router to Mikrotik RB2011uias-2hnd-in (RouterOS v6.46.3 (stable)).
Did a factory configuration reset and have just set SSID and WEB2 password for WiFi.
Provider promises 100 Mbit/s.
My LAN ubuntu server (using speedtest-cli) shows:
Hosted by KeFF Networks (Kista) [4.78 km]: 2.076 ms
Testing download speed.........................................................a.......................
Download: 95.84 Mbit/s
Testing upload speed......................................................................................................
Upload: 2.93 Mbit/s
Which is promising :wink:
My WiFi ubuntu laptop (using speedtest-cli) on a distance on 4m from router shows:
Hosted by Tele2 (Kista) [4.71 km]: 9.398 ms
Testing download speed................................................................................
Download: 36.59 Mbit/s
Upload: 3.64 Mbit/s
Which is 3 times slower :o :shock:
While my iPhone 7+ (using speedtest iOS app) on a distance on 4m from router shows:
Download - 18.1 Mbit/s
Upload - 9.41 Mbit/s
And friend's Galaxy S10+ (using speedtest Android app) same 4m distance gives:
Download- 33.3 Mbit/s
Upload - 7.62 Mbit/s
Can someone please help me to understand the bottleneck and how do I properly make a home network?
My goal is to have a stable WiFi in apartment(3 rooms apartment) with about max 10-15 devices connected simultaneously (a few phones, laptops, and Philips smart bulbs)
Here is my Mikrotik config export:
[admin@MikroTik] > /export
# feb/22/2020 12:18:18 by RouterOS 6.46.3
# software id = 63WL-9G9C
# model = 2011UiAS-2HnD
# serial number = 467304B1DBAF
add admin-mac=4C:5E:0C:43:D6:3E auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX country=sweden disabled=no distance=indoors frequency=auto installation=indoor mode=ap-bridge ssid="The Apartment" wireless-protocol=802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys supplicant-identity=MikroTik wpa-pre-shared-key=Kollektiv! wpa2-pre-shared-key=Kollektiv!
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=ether9
add bridge=bridge comment=defconf interface=ether10
add bridge=bridge comment=defconf interface=sfp1
add address=192.168.88.1/24 comment=defconf interface=ether2 network=192.168.88.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
set allow-remote-requests=yes
/ip dns static
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/lcd interface pages
set 0 interfaces=wlan1
/system clock
set time-zone-name=Europe/Stockholm
/system routerboard settings
set auto-upgrade=yes cpu-frequency=700MHz silent-boot=yes
/tool mac-server
/tool mac-server mac-winbox
Thank you in advance for any help
erlinden
Long time Member
Long time Member
Re: Super slow WiFi speed on default configuration
Sat Feb 22, 2020 2:42 pm
Default wireless configuration is like not really optimized...
To get best performance:
- use 20MHz bandwidth
- choose channel manually, either 2412/2437/2462 (perform a scan to get least used channel)
- set encryption on aes-ccm
Besides...what are you expecting? And what made you choose the RB2011 (with 2G only)?
First the problem, then the solution
ilja
Sat Feb 22, 2020 4:42 pm
Thank you for your answer and help, @erlinder.
I have put all suggested optimizations, but it didn't seem to change much.
My expectation would be to get 90+ mbps/s on WiFi, when operator promises 100 mbps/s on cable. Is that a realistic expectation at all?
By “2G only” you mean the router with 2GHz alone? Honestly, I didn’t have much choice when getting it, but I was aware that I would want to add 5GHz band, so my idea was to get a more less powerful “core”(RB2011) and then add an access point which would support 5GHz down the road
rudidxc
Wed Nov 11, 2020 11:04 am
Hi. Did you ever figure this out? I'm sitting in the same boat at the moment.
erlinden
Long time Member
Long time Member
Wed Nov 11, 2020 11:34 am
I think the conclusion not to expect too much wirelessly of this device as it is 2.4GHz only answers your question...
jimfizz
Mon Jan 18, 2021 10:55 am
I had the same issue... resulted in me sending the device back for a refund.
Msosa
Mon Feb 01, 2021 6:06 am
Hi guys, it seems to be a good performance for a 2.4Ghz WiFi. If need fly faster you should buy a RB with 5Ghz antenna.
By other hand the default WiFi config it's not working well for me. I'm just getting 10Mbps on 2.4 WiFi. Really bad!!
Limiting AMSDU to 2048 I get a non stable improvement on performance.
santyx32
Tue Feb 02, 2021 1:51 am
MT's non wave2 WiFi sucks but it's also true that you can't get fast 2.4GHz if you are on a crowded environment. When I was living on the suburbs I used to get 100-110Mbps with an old router on 2.4GHz (20MHz) using a 2x2 client but on the city I can only get 70Mbps at best using OpenWrt or 25Mbps with ROS on hAP ac2, 5GHz is fast on both but ROS WiFi has always been unreliable for me.
Users browsing this forum: No registered users and 35 guests
