derwulz
LTE with A1 Dataguard
Tue Mar 10, 2020 12:43 am
i use an Mikrotik wAP (RBwAPGR-5HacD2HnD) Router.
SIM is from Network Austria A1 and is an private Network inside public network. It is calles Dataguard in Austria.
This works with an user defined "APN" inside mobile network. We have a lot of SIM cards with networks.
Every SIM Card is an private network assigned.
Example
SIM1 net: 192.168.100.0/24
SIM2 net: 192.168.101.0/24
SIM3 net: 192.168.102.0/24
and so on...
When i Access the LTE network, i get an IP-Adress inside "192.168.99.0/24" network on LTE interface.
Automatically Default Route access to LTE
My LAN interface is an Bridge with both ethernet ports inside, and IP of SIM1 192.168.100.1/24 is set on interface Bridge and of course SIM1 inserted.
On an second router with SIM2 inserted is IP 192.168.101.1/24 set on Bridge.
My router 1 (with SIM1) got 192.168.99.2 from LTE
My router 2 (with SIM2) got 192.168.99.3 from LTE
Both dataguard IP's and not changeable from me.
When i try to PING the router 2 with IP 192.168.101.1 from Router with LAN IP 192.168.100.1 it is NOT possible.
(LTE is connected and all seems to be fine), when I "disable - wait - enable" the LTE interface, it reconnects again like same as before
and now the PING works.
So if i reboot the router, no PING is possible. Also no routing seems to be done. If i do my "disable - wait - enable" the LTE interface all works fine. Also routing!
(an PC with IP 192.168.101.2 behind Router 192.168.101.1 and PINGed from Device 192.168.100.2 behind Router 192.168.100.1)
I don't understand what's the difference between "connected after reboot" and "disable - wait - enable" of the interface. Which causes only an "reconnect".
maybe other people can help me
(Firmware ist last stable from mikrotik site 6.46.4 ARM)
regards
SiB
Re: LTE with A1 Dataguard
Tue Mar 10, 2020 10:55 am
First, give details about modem what you use.
MTCNA + MTCRE + MTCINE | ~600 users at ~150 RouterBoards in EMEA | Telegram: @SiB_PL
WinBox Tip: F6 works as ALT+TAB | Gliffy.com - free network schematic | prnt.sc - free ScreenShot software
I back :) Hello again.
derwulz
Tue Mar 10, 2020 1:47 pm
built in Modem:
Mirkotik
R11e LTE
Revision CP 2.160.000 v012
Here is the log from LTE Modem:
after boot not working:
12:08:01 lte,async lte1: sent AT E0 V1
12:08:01 lte,async lte1: rcvd OK
12:08:01 lte,async lte1: sent AT+CGMI
12:08:01 lte,async lte1: rcvd +CGMI: "MikroTik"
12:08:01 lte,async lte1: sent AT+CGMM
12:08:01 lte,async lte1: rcvd +CGMM: "R11e-LTE"
12:08:01 lte,async lte1: sent AT+CGMR
12:08:01 lte,async lte1: rcvd +CGMR: "MikroTik_CP_2.160.000_v012"
12:08:01 lte,async lte1: sent AT+CGSN
12:08:01 lte,async lte1: rcvd +CGSN: #long-number#
12:08:01 lte,async lte1: sent AT+CFUN?
12:08:01 lte,async lte1: rcvd +CFUN: 1
12:08:01 lte,async lte1: sent AT+CFUN=4
12:08:02 lte,async,event lte1: ^SRVST: 0
12:08:02 lte,async,event lte1: +CGEV: ME DETACH
12:08:02 lte,async lte1: rcvd OK
12:08:02 lte,async lte1: sent AT+CFUN?
12:08:02 lte,async lte1: rcvd +CFUN: 4
12:08:02 lte,async lte1: sent AT+CMEE=2
12:08:02 lte,async lte1: sent AT+CREG=2
12:08:02 lte,async lte1: sent AT+CGREG=2
12:08:02 lte,async lte1: sent AT+CEREG=2
12:08:02 lte,async lte1: sent AT+CGEREP=2,0
12:08:02 lte,async lte1: sent AT+CMGF=0
12:08:02 lte,async lte1: sent AT+CNMI=1,1,0,1,0
12:08:02 lte,async lte1: sent AT+EEMOPT=1
12:08:02 lte,async lte1: sent AT*MRD_SN?
12:08:02 lte,async lte1: rcvd *MRD_SN:#serialnr#
12:08:02 lte,debug lte1: serial: *MRD_SN:#serialnr#
12:08:02 lte,async lte1: sent AT+CFUN=4
12:08:02 lte,async lte1: sent AT*CGDFLT=0,"IP","customer.a1.net",,,,,,,,,,1,0,,,,,,,1
12:08:02 lte,async lte1: sent AT*CGDFAUTH=0,2,"ppp@a1plus.at","ppp"
12:08:02 lte,async lte1: sent AT+CPIN?
12:08:02 lte,async lte1: rcvd +CPIN: SIM PIN
12:08:02 lte,async lte1: sent AT+CPIN="1234"
12:08:03 lte,async,event lte1: +CPIN: READY
12:08:03 lte,async,event lte1: ^SIMST: 1
12:08:03 lte,async lte1: rcvd +CFUN: 4
12:08:03 lte,async lte1: sent AT+CMEE=2
12:08:03 lte,async lte1: rcvd OK
12:08:03 lte,async lte1: sent AT+CREG=2
12:08:03 lte,async lte1: sent AT+CGREG=2
12:08:03 lte,async lte1: sent AT+CEREG=2
12:08:03 lte,async lte1: sent AT+CGEREP=2,0
12:08:03 lte,async lte1: sent AT+CMGF=0
12:08:03 lte,async lte1: sent AT+CNMI=1,1,0,1,0
12:08:03 lte,async lte1: sent AT+EEMOPT=1
12:08:03 lte,async lte1: sent AT*MRD_SN?
12:08:04 lte,async lte1: rcvd *MRD_SN:#serialnr#
12:08:04 lte,debug lte1: serial: *MRD_SN:#serialnr#
12:08:04 lte,async lte1: sent AT+CFUN=4
12:08:04 lte,async lte1: rcvd OK
12:08:04 lte,async lte1: sent AT*CGDFLT=0,"IP","customer.a1.net",,,,,,,,,,1,0,,,,,,,1
12:08:04 lte,async lte1: sent AT*CGDFAUTH=0,2,"ppp@a1plus.at","ppp"
12:08:04 lte,async lte1: sent AT+CPIN?
12:08:04 lte,async lte1: rcvd +CPIN: READY
12:08:05 lte,async,event lte1: +MMSG: 2, 0
12:08:05 lte,async,event lte1: +MMSG: 3, 0
12:08:05 lte,async,event lte1: +MMSG: 0, 0
12:08:05 lte,async,event lte1: +MPBK: 1
12:08:08 lte,async lte1: sent AT+CPMS="SM","SM","SM"
12:08:08 lte,async lte1: rcvd +CPMS: 0,20,0,20,0,0
12:08:08 lte,async lte1: sent AT+CFUN?
12:08:08 lte,async lte1: rcvd +CFUN: 4
12:08:08 lte,async lte1: sent AT+ICCID?
12:08:08 lte,async lte1: rcvd +ICCID: #longnumber#
12:08:08 lte,async lte1: sent AT+CNUM
12:08:08 lte,async lte1: rcvd +CME ERROR: 100
12:08:08 lte,async lte1: sent AT+CIMI
12:08:08 lte,async lte1: rcvd #serial-cimi#
12:08:08 lte,async lte1: sent AT+CPIN?
12:08:08 lte,async lte1: rcvd +CPIN: READY
12:08:08 lte,async lte1: sent AT*BAND=1,78,147,160,524487,0,2,0
12:08:08 lte,async lte1: rcvd OK
12:08:09 lte,async lte1: sent AT+COPS=0
12:08:09 lte,async lte1: rcvd OK
12:08:09 lte,async lte1: sent AT+CFUN=1
12:08:09 lte,async lte1: sent AT+COPS=3,0
12:08:09 lte,debug lte1: config ok
12:08:12 lte,debug lte1: network access technology: 3G
12:08:12 lte,info lte1: registered home
12:08:14 lte,async lte1: sent AT+CGDCONT=5,"IP","customer.a1.net"
12:08:14 lte,async lte1: rcvd OK
12:08:14 lte,async lte1: sent AT*AUTHReq=5,2,"ppp@a1plus.at","ppp"
12:08:14 lte,async lte1: sent AT+CGDATA="",5
12:08:16 lte,debug lte1: network access technology: 3G HSDPA
12:08:16 lte,async,event lte1: +CGEV: ME ACT ""IP"", "192.168.99.2",5
12:08:16 lte,async lte1: rcvd CONNECT
12:08:17 lte,async lte1: sent AT+CGDCONT?
12:08:17 lte,async lte1: rcvd +CGDCONT: 5,"IP","customer.a1.net","192.168.99.2",,,#very-long-string#,
12:08:17 lte,async lte1: sent AT+CGCONTRDP=5
12:08:17 lte,async lte1: rcvd +CGCONTRDP: 5,5,"customer.a1.net","192.168.99.2","","","8.8.8.8","9.9.9.9","","","0","0"
12:08:17 interface,info lte1 link up
12:08:21 lte,debug lte1: network access technology: 3G
And working after "disconnect - wait - reconnect":
12:13:10 lte,account lte1 session: 293s 1008/9644 bytes 24/125 packets
12:13:10 lte,async lte1: sent AT E0 V1
12:13:10 interface,info lte1 link down
12:13:10 lte,async lte1: rcvd OK
12:13:10 lte,async lte1: sent AT+CFUN=0
12:13:11 lte,async,event lte1: +CGEV: NW DEACT ""IP"", "192.168.99.2",5
12:13:11 lte,async lte1: rcvd
12:13:11 lte,async,event lte1: +CGEV: ME DETACH
12:13:11 lte,async,event lte1: ^SIMST: 0
12:13:11 lte,async,event lte1: +MMSG: 1, 0
12:13:11 lte,async,event lte1: +CPIN: SIM REMOVED
12:13:11 lte,async,event lte1: ^CARDMODE: 255
12:13:11 lte,async,event lte1: ^SIMST: 255,0
12:13:12 lte,async lte1: sent AT E0 V1
12:13:12 lte,async lte1: rcvd OK
12:13:12 lte,async lte1: sent AT+CFUN?
12:13:12 lte,async lte1: rcvd +CFUN: 0
12:13:12 lte,async lte1: sent AT+CFUN=4
12:13:17 lte,async lte1: rcvd OK
12:13:17 lte,async lte1: sent AT+CFUN?
12:13:17 lte,async,event lte1: ^SIMST: 0
12:13:17 lte,async,event lte1: +CPIN: SIM PIN
12:13:17 lte,async,event lte1: ^CARDMODE: 255
12:13:17 lte,async,event lte1: ^SIMST: 255,1
12:13:17 lte,async lte1: rcvd +CFUN: 4
12:13:17 lte,async lte1: sent AT+CMEE=2
12:13:17 lte,async lte1: sent AT+CREG=2
12:13:17 lte,async lte1: sent AT+CGREG=2
12:13:17 lte,async lte1: sent AT+CEREG=2
12:13:17 lte,async lte1: sent AT+CGEREP=2,0
12:13:17 lte,async lte1: sent AT+CMGF=0
12:13:17 lte,async lte1: sent AT+CNMI=1,1,0,1,0
12:13:17 lte,async lte1: sent AT+EEMOPT=1
12:13:17 lte,async lte1: sent AT*MRD_SN?
12:13:17 lte,async lte1: rcvd *MRD_SN:#serialnr#
12:13:17 lte,debug lte1: serial: *MRD_SN:#serialnr#
12:13:17 lte,async lte1: sent AT+CFUN=4
12:13:17 lte,async lte1: sent AT*CGDFLT=0,"IP","customer.a1.net",,,,,,,,,,1,0,,,,,,,1
12:13:17 lte,async lte1: sent AT*CGDFAUTH=0,2,"ppp@a1plus.at","ppp"
12:13:17 lte,async lte1: sent AT+CPIN?
12:13:17 lte,async lte1: rcvd +CPIN: SIM PIN
12:13:17 lte,async lte1: sent AT+CPIN="1234"
12:13:18 lte,async,event lte1: +CPIN: READY
12:13:18 lte,async,event lte1: ^SIMST: 1
12:13:18 lte,async lte1: rcvd +CFUN: 4
12:13:18 lte,async lte1: sent AT+CMEE=2
12:13:18 lte,async lte1: rcvd OK
12:13:18 lte,async lte1: sent AT+CREG=2
12:13:18 lte,async lte1: sent AT+CGREG=2
12:13:18 lte,async lte1: sent AT+CEREG=2
12:13:18 lte,async lte1: sent AT+CGEREP=2,0
12:13:18 lte,async lte1: sent AT+CMGF=0
12:13:18 lte,async lte1: sent AT+CNMI=1,1,0,1,0
12:13:18 lte,async lte1: sent AT+EEMOPT=1
12:13:18 lte,async lte1: sent AT*MRD_SN?
12:13:19 lte,async lte1: rcvd *MRD_SN:#serialnr#
12:13:19 lte,debug lte1: serial: *MRD_SN:#serialnr#
12:13:19 lte,async lte1: sent AT+CFUN=4
12:13:19 lte,async lte1: rcvd OK
12:13:19 lte,async lte1: sent AT*CGDFLT=0,"IP","customer.a1.net",,,,,,,,,,1,0,,,,,,,1
12:13:19 lte,async lte1: sent AT*CGDFAUTH=0,2,"ppp@a1plus.at","ppp"
12:13:19 lte,async lte1: sent AT+CPIN?
12:13:19 lte,async lte1: rcvd +CPIN: READY
12:13:20 lte,async,event lte1: +MMSG: 2, 0
12:13:20 lte,async,event lte1: +MMSG: 3, 0
12:13:20 lte,async,event lte1: +MMSG: 0, 0
12:13:20 lte,async,event lte1: +MPBK: 1
12:13:23 lte,async lte1: sent AT+CPMS="SM","SM","SM"
12:13:23 lte,async lte1: rcvd +CPMS: 0,20,0,20,0,0
12:13:23 lte,async lte1: sent AT+CFUN?
12:13:23 lte,async lte1: rcvd +CFUN: 4
12:13:23 lte,async lte1: sent AT+ICCID?
12:13:23 lte,async lte1: rcvd +ICCID: #long-number#
12:13:23 lte,async lte1: sent AT+CNUM
12:13:23 lte,async lte1: rcvd +CME ERROR: 100
12:13:23 lte,async lte1: sent AT+CIMI
12:13:23 lte,async lte1: rcvd #serial-cimi#
12:13:23 lte,async lte1: sent AT+CPIN?
12:13:23 lte,async lte1: rcvd +CPIN: READY
12:13:23 lte,async lte1: sent AT*BAND=1,78,147,160,524487,0,2,0
12:13:23 lte,async lte1: rcvd OK
12:13:24 lte,async lte1: sent AT+COPS=0
12:13:24 lte,async lte1: rcvd OK
12:13:24 lte,async lte1: sent AT+CFUN=1
12:13:24 lte,async lte1: sent AT+COPS=3,0
12:13:24 lte,debug lte1: config ok
12:13:27 lte,debug lte1: network access technology: 3G
12:13:27 lte,info lte1: registered home
12:13:29 lte,async lte1: sent AT+CGDCONT=5,"IP","customer.a1.net"
12:13:29 lte,async lte1: rcvd OK
12:13:29 lte,async lte1: sent AT*AUTHReq=5,2,"ppp@a1plus.at","ppp"
12:13:29 lte,async lte1: sent AT+CGDATA="",5
12:13:31 lte,debug lte1: network access technology: 3G HSDPA
12:13:31 lte,async lte1: rcvd CONNECT
12:13:31 lte,async,event lte1: +CGEV: ME ACT ""IP"", "192.168.99.2",5
12:13:32 lte,async lte1: sent AT+CGDCONT?
12:13:32 lte,async lte1: rcvd +CGDCONT: 5,"IP","customer.a1.net","192.168.99.2",,,#long-string#,
12:13:32 lte,async lte1: sent AT+CGCONTRDP=5
12:13:32 lte,async lte1: rcvd +CGCONTRDP: 5,5,"customer.a1.net","192.168.99.2","","","8.8.8.8","9.9.9.9","","","0","0"
12:13:32 interface,info lte1 link up
regards
SiB
Wed Mar 11, 2020 1:55 am
I bet you not check this logs in any text compare software.
They are the same, only difference are at front.
PLEASE UPGRADE MODEM FIRMWARE to v15 who is LATEST for your modem.
I not say/write about ROS version or boot-firmware.
This one:
/interface lte firmware-upgrade lte1
derwulz
Wed Mar 11, 2020 8:22 am
This one:
Yes sorry - didn't compare with text-software only with "eyes" side by side.
i get this message on upgrade:
status: connection error
SiB
Wed Mar 11, 2020 10:38 am
You not read documentation: https://wiki.mikrotik.com/wiki/Manual:I ... re_upgrade
Modem firmware upgrade
Starting from RouterOS version 6.44beta20 it is possible to upgrade modems firmware.
Firmware update is available only as FOTA Firmware Over The Air - firmware upgrade can only be done through working mobile connection for:
)R11e-LTE
This means, you must provide SIM card with internet to do a firmware upgrade.
You can do a scheduler at startup who will delay 10s and do re-enable the lte1 interface. But this is a workaround , not fix.
derwulz
Wed Mar 11, 2020 11:05 am
of course, that's now present. I did this for first workaround. But i need an workable solution.
Okay i try an SIM with internet access, those i use have no internet access - private network.
regards
derwulz
[SOLVED ] LTE with A1 Dataguard  [SOLVED]
Wed Mar 25, 2020 9:44 am
It was an problem with the modem firmware.
Mikrotik analyzed and fixed in Firmware v016. Others with same problem - do an OTA update of firmware and you're lucky.
regards
SiB
Re: [SOLVED ] LTE with A1 Dataguard
Wed Mar 25, 2020 11:47 pm
derwulz
Other have a still v15 as latest. What you mean about OTA ?
derwulz
Thu Mar 26, 2020 2:00 pm
derwulz
Yes! you're right. officcially is only 015 available. 016 will be released soon, after some internal tests.
This edition was made only in my case available.
regards
M
Users browsing this forum: Baidu [Spider] and 50 guests
