robmaltsystems
Low signal when using USB Wi-FI adaptor with hAP Lite
Thu Mar 26, 2020 2:05 pm
I've got a generic USB Wi-Fi connector that I occasionally plug into my PC so I can do "wireless" stuff. However, it's getting a very poor signal with a hap Lite. The router is currently 3m away from the PC/adaptor but this is the strengh:
So note how low the Mikrotik is compared to my other Wi-Fi network Middle-Earth which is on the other side of the room. But my mobile phone has a perfectly good signal and that's right next to the USB adaptor:
Any ideas?
robmaltsystems
Re: Low signal when using USB Wi-FI adaptor with hAP Lite
Thu Mar 26, 2020 2:14 pm
I've just plugged the USB adaptor into my laptop and same problem. Use the laptop inbuilt Wi-Fi and totally strong signal. Use the USB Wi-Fi adaptor and very low signal. Can get a slightly better signal if I move the laptop right next to the router but still only one bar.
So this particular USB Wi-Fi adaptor is struggling with hAP Lite Wi-Fi...
I've got a couple more Mikrotik routers in the cupboard. Will give them a go.
w32pamela
Thu Mar 26, 2020 8:15 pm
Sounds like the USB adapter is bad.
robmaltsystems
Thu Mar 26, 2020 10:16 pm
Hmm, sort of - it works fine with every other Wi-Fi access point and I live somewhere where there are lots of access points:
It's perplexing but does seem to be a problem between the USB adaptor and the hAP lite alone.
w32pamela
Fri Mar 27, 2020 11:03 pm
In post #2 you said the laptop with built in wifi got a strong signal but that when you plugged in the USB wifi it got a poor signal.
robmaltsystems
Sat Mar 28, 2020 12:05 am
It got a strong signal when using the in-built Wi-Fi interface but low when using the USB-adapter. So the signal is clearly strong but something else is causing it to report/run low signal. It's very weird.
macsrwe
Forum Veteran
Forum Veteran
Sat Mar 28, 2020 1:02 am
Change the channel on the hAP and see if that improves things. You could be "auto"ing to a channel your USB dongle doesn't work with.
Users browsing this forum: No registered users and 49 guests
