techlord
HAP AC Lite WIFI issue with CAPSMAN
Tue Jun 23, 2020 1:19 pm
Hi guys!
Got a small issue I can't find a solution for.
Setup:
Main router - RB3011 running CAPSMAN
3 xAPs - 2x CAP AC + 1x HAP AC Lite
- 2 x SSIDs, one for each band, manual settings of the channels so they do not overlap
Issue:
Roaming with an Android 9 phone between the CAP ACs works flawless but roaming from any CAP AC to the HAP AC Lite fails 50% of the time. The failure looks like this:
1. Client ( Android Phone) goes to bad signal from the CAP AC - > access list rejects it -> registers to HAP AC Lite on the same SSID
2. 50% of time the connection to the HAP AC LT gets an exclamation mark and nothing works (Internet, other devices in the lan). Within a few minutes (2-3) the exclamation mark disappears and everything works again.
- the other 50% of the time the roaming is fast with no issues.
- happens on both SSIDs
- never happened when roaming from CAP AC to CAP AC
- nothing relevant in the logs
You might say it's an Android issue but why does this not happen from cAP AC to cAP ac? Went through several SW versions, nothing changed.
Here is my capsman config:
/caps-man channel
add band=2ghz-g/n name=2GHZchannel skip-dfs-channels=no
add band=5ghz-a/n/ac name=5GHZchannel skip-dfs-channels=no
add band=2ghz-g/n extension-channel=Ce frequency=2437 name=channel6-2.4ghz
add band=2ghz-g/n extension-channel=Ce frequency=2412 name=channel1-2.4ghz
add band=2ghz-g/n extension-channel=eC frequency=2462 name=channel11-2.4ghz
add band=5ghz-n/ac extension-channel=Ceee frequency=5500 name=ch100-5ghz
add band=5ghz-n/ac extension-channel=Ceee frequency=5660 name=ch132-5ghz
add band=5ghz-n/ac extension-channel=Ceee frequency=5180 name=ch36-5ghz
add band=5ghz-n/ac extension-channel=Ceee frequency=5260 name=ch52-5ghz
/caps-man rates
add basic=12Mbps name=rate1 supported=12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps
/caps-man security
add authentication-types=wpa2-psk encryption=aes-ccm name=security1
/caps-man access-list
add action=accept allow-signal-out-of-range=10s client-to-client-forwarding=yes disabled=no interface=\
    all signal-range=-79..120 ssid-regexp="" time=0s-1d,sun,mon,tue,wed,thu,fri,sat
add action=accept allow-signal-out-of-range=10s disabled=no interface=any mac-address=D8:F1:5B:92:44:4A \
    signal-range=-120..120 ssid-regexp="" time=0s-1d,sun,mon,tue,wed,thu,fri,sat
add action=reject allow-signal-out-of-range=10s disabled=no interface=all signal-range=-120..-80 \
/caps-man configuration
add channel=5GHZchannel country=romania datapath=datapath1 installation=indoor mode=ap name=cfg1 rates=\
    rate1 security=security1 ssid=Nistors5G
add channel=2GHZchannel country=romania datapath=datapath1 installation=indoor mode=ap name=cfg2 \
/caps-man datapath
add bridge=bridge client-to-client-forwarding=yes local-forwarding=yes name=datapath1
/caps-man interface
add channel=channel6-2.4ghz comment=WIFI configuration=cfg2 disabled=no l2mtu=1600 mac-address=\
    C4:AD:34:12:B5:46 master-interface=none name=wifi-fl1-2g radio-mac=C4:AD:34:12:B5:46 radio-name=\
    C4AD3412B546
add channel=ch52-5ghz configuration=cfg1 disabled=no l2mtu=1600 mac-address=C4:AD:34:12:B5:47 \
    master-interface=none name=wifi-fl1-5g radio-mac=C4:AD:34:12:B5:47 radio-name=C4AD3412B547
add channel=channel1-2.4ghz configuration=cfg2 disabled=no l2mtu=1600 mac-address=CC:2D:E0:92:22:30 \
    master-interface=none name=wifi-gnd-2g radio-mac=CC:2D:E0:92:22:30 radio-name=CC2DE0922230
add channel=ch100-5ghz configuration=cfg1 disabled=no l2mtu=1600 mac-address=CC:2D:E0:92:22:31 \
    master-interface=none name=wifi-gnd-5g radio-mac=CC:2D:E0:92:22:31 radio-name=CC2DE0922231
add channel=channel11-2.4ghz configuration=cfg2 configuration.installation=outdoor disabled=no l2mtu=\
    1600 mac-address=C4:AD:34:C3:0B:06 master-interface=none name=wifi-grd-2g radio-mac=\
    C4:AD:34:C3:0B:06 radio-name=C4AD34C30B06
add channel=ch36-5ghz configuration=cfg1 disabled=no l2mtu=1600 mac-address=C4:AD:34:C3:0B:05 \
    master-interface=none name=wifi-grd-5g radio-mac=C4:AD:34:C3:0B:05 radio-name=C4AD34C30B05
/caps-man manager
set ca-certificate=auto certificate=auto enabled=yes
/caps-man manager interface
set [ find default=yes ] forbid=yes
add disabled=no interface=bridge
/caps-man provisioning
add action=create-enabled hw-supported-modes=ac,an master-configuration=cfg1
add action=create-enabled hw-supported-modes=gn master-configuration=cfg2
Could it be a bug in the HAP AC Lite? Maybe different implementation of some protocol ( ARM vs MIPSBE)...
Any ideas?
bitracer
Re: HAP AC Lite WIFI issue with CAPSMAN
Thu Jun 25, 2020 12:20 pm
I also have an issue with hAP ac lite and CAPsMAN.
Occasionally, iOS devices connected to this AP lose internet connection even though the device is connected and with good signal (more than -60). If the WiFi is switched off and turned on again, the devices rejoins the same access point and the internet access works without issues.
This never happens with the other APs managed by the same CAPsMAN. I tried various tips, like enabling WMM mangle rules on the AP, extending the DHCP lease, still no luck. It happens sporadically, but still it's annoying.
erlinden
Thu Jun 25, 2020 12:57 pm
What RouterOS version are you running on all devices? Are all firmwares at the same version?
First the problem, then the solution
bitracer
Thu Jun 25, 2020 3:00 pm
I'm running v6.47 (currently the latest stable) on all devices. Yes, also the firmware is the same on all devices.
techlord
Thu Jun 25, 2020 3:41 pm
Bitracer, seems our issues are related. Is your AP losing Internet for already connected devices or only when you roam to it? From what I can see, once connected to the AP and working I do not lose the Internet connection anymore, it's just when I'm first connecting (via roaming) that I see issues.
bitracer
Thu Jun 25, 2020 5:11 pm
On my side the devices lose connection even though connection was established (and working) for some time. I can't confirm if this also happens as soon as devices join the access point, but it could also be the case.
angriukas
Thu Jun 25, 2020 5:19 pm
Did you add to the logging "caps" topic, still nothing in the log?
bitracer
Thu Jun 25, 2020 5:57 pm
I see the migrations from AP to AP, but the moment it happens nothing specifically. The device is happily connected to he AP, it's reporting strong signal, I see the device in the registration table in CAPsMAN, but internet doesn't work. I haven't tried device to device communication. This is something I can check next.
Turning the WiFi off and then on resolves the issue immediately, and other devices on the same AP exhibit no problems at that very moment.
bitracer
Thu Jun 25, 2020 6:09 pm
@techlord Have you tried switching to 20MHz channel width for the 2GHz band (no channel extension)?
techlord
Thu Jun 25, 2020 6:13 pm
I did not try to play with that but I also see this on the 5GHZ network. Thinking of raising a ticket with support.
bitracer
Thu Jun 25, 2020 6:38 pm
You should, I opened one for my issue.
bitracer
Re: HAP AC Lite WIFI issue with CAPSMAN  [SOLVED]
Fri Jun 26, 2020 11:17 am
Mikrotik came back to me related to this issue. Apparently there is an issue with the software implementation around the switch.
It's been fixed in 6.48beta2 which is not released yet to the public:
https://box.mikrotik.com/f/60329d300318413b9d27/?dl=1
The fix will be included in future public releases.
techlord
Fri Jun 26, 2020 11:44 am
Great news! Thanks for chasing this.
Did you install it? Any issues? Wondering if it will have issues running with lower ROS CAPSMAN
bitracer
Fri Jun 26, 2020 12:22 pm
Yes, I installed it and I'm testing it now. So far so good, no obvious issues. I installed it only on hAP ac lite, of course.
freemannnn
Long time Member
Long time Member
Sat Jun 27, 2020 7:31 am
does this affect only hap ac lite?
i was having same problem when roaming on hap ac lite from main ssid to slave ssid. lost many hours trying to find why this was happening. i am at 6.45.9.
problem went away when instead of using local forwading, i use capsman forwarding.
can you test without local forwarding with 6.47 and lower please?
bitracer
Sun Jun 28, 2020 11:02 pm
It's been few days now and the issue appears to be resolved. Didn't have any more connectivity issues when clients are connected with hAP ac lite AP.
I've tried briefly to route traffic through the CAPsMAN, that works too. I couldn't test with previous releases since I already upgraded the device to this release and didn't have time to fiddle with it.
techlord
Mon Jun 29, 2020 10:04 am
Hi bitracer.
Wanted to confirm that my issues got resolved with that ROS version. Roaming is now smooth with no issues. The only (small) complain I have to Mikrotik devs is that all these newer ROS version do seem to write a LOT to the flash.
So thanks for sharing!
Users browsing this forum: FranJRL and 34 guests
