SergeS
How to switch default Security Profile in Winbox?
Tue Jun 23, 2020 8:48 pm
I have two security profiles in wireless settings. How to switch default one using Winbox?
WeWiNet
Re: How to switch default Security Profile in Winbox?
Tue Jun 23, 2020 9:19 pm
In the Wireless Interface tab, under settings you can chose many things, including which security profile to use for that
wireless interface...
WeWiNet
MTCNA
I like a new challenge, I migrate to ROS7... :? or maybe I am just crazy :lol: !!!
sutrus
Tue Jun 23, 2020 9:23 pm
Wireless -> Wireless inteface tab select interface and double clik on.
On new windows select Wireless tab and change "Security profile"
SergeS
Tue Jun 23, 2020 9:45 pm
I did not mean how to change security profile used in specific wireless interface, I know that. My question is about default security profile, which marks with * and cannot be deleted.
I would like to delete default security profile, which is not allowed.Image
sutrus
Tue Jun 23, 2020 9:54 pm
You can't remove it, but should be able to change it.
SergeS
Tue Jun 23, 2020 10:04 pm
That what my question exactly is - how to change it?
mkx
Wed Jun 24, 2020 8:36 am
Double-click it and change its properties ...
BR,
Metod
WeWiNet
Wed Jun 24, 2020 1:01 pm
SergeS,
For me there are more important things than changing the name of the default sec profile which you can not do if you
use device with default config.
(Just don;t use this profile and put for security a long pass phrase into it... )
I think the only way to get rid of the default profile is, if you do not use default config and start from scratch.
Reset the router and do not use the proposed AP setup (or whatever is default on your device).
Then you can add just what you want and then (I believe) you can use the name you want.
But be careful, I have not tested this recently and with every ROS update things change in ROS, its like moving sand... ;-)
(and please put right problem description into your next post topic)
WeWiNet
MTCNA
SergeS
Wed Jun 24, 2020 5:05 pm
Did you try by yourself? What specific property?
SergeS
Wed Jun 24, 2020 5:09 pm
SergeS,
Wrong. I am not using default profile, and that is why I would like to remove it. I cannot, because it is DEFAULT profile :-)
That is exactly what i am trying to do and seems to me my description of the problem is correct.
P.S. Reset the whole router??? Are you kidding?
WeWiNet
Wed Jun 24, 2020 5:49 pm
MKX,
on some devices (my Audience for example) you can no longer remove or name change the default profile.
It shows the error message SergeS showed.
I don't know when/how that happened, as I have hap / map devices on which I have it removed or renamed
but that was on older ROS versions.
SergeS,
having an unused DEFAULT profile is not a problem or issue! I understand it would be cleaner to rename it in the list
but as you do not use it in the wireless interface it does not harm... You can select key, and passphrase to make
sure in case you would accidentally use that profile you do not open your Wifi network.
ROS has enough other issues to solve than this one...
WeWiNet
MTCNA
SergeS
Wed Jun 24, 2020 7:33 pm
SergeS,
Yes, absolutely, it is not a problem to keep it unused, it is true.
So, no way to delete it? I am not blaming OS, I thought Ii it simple question, and I need to educate myself on how to do it.
plcs
Mon Dec 28, 2020 5:42 pm
"New Terminal"
interface wireless [ENTER]
set security-profile="your-security-profile-name" [ENTER]
or by using www interface.
When you set security profile like above your winbox show you option "Security profile"
Users browsing this forum: No registered users and 39 guests
