zerospace
CAPSMAN issue with new CAP
Mon Jun 29, 2020 8:07 pm
Hi all,
Need some help with CAPSMAN setup.
Till some hour ago setup was like this
internet->HAP AC2 (router&CAPSMAN&CAP)->some TP link (switch&AP)->HAP AC2 (switch&CAP) and all was fine. -> is wire connection.
Now I replaced TP link with another HAP AC2, so now setup is:
internet->HAP AC2 (name MK1, router&CAPSMAN&CAP)->HAP AC2 (MK2, switch&CAP)->HAP AC2 (MK3, switch&CAP). IPs are
MK1: 192.168.10.1
MK2: 192.168.10.2
MK3: 192.168.10.3
MK1 and MK3, from old setup work fine.
But MK2, newly added HAP AC2 is working, but strange somehow. It's radios don't have RSMB status, but are DSMB. This D being dynamic, and everything I change something, CAP names for it go 1 number larger, right now, it's radios are named CAP89&90... and I cannot set anything on them from CAPSMAN, chanel, or anything, everything is grayed out.
I am a bit new to the Mikrotik, hope I explained it good.
Is there any fix to this?
Zacharias
Re: CAPSMAN issue with new CAP
Mon Jun 29, 2020 8:11 pm
On the provisioning tab under action field instead of Create-dynamic-enabled you should select create-enabled....
zerospace
Mon Jun 29, 2020 8:34 pm
Thank you, it worked.
First I selected it but nothing changed. Restarted router, and it changed :)
Zacharias
Re: CAPSMAN issue with new CAP  [SOLVED]
Mon Jun 29, 2020 8:41 pm
You could just reprovision the radio instead of rebooting...
You can mark the post as solved...
Users browsing this forum: FranJRL and 31 guests
