swang2002
wAP 60Gx3 clients keep disconnecting
Wed Sep 09, 2020 3:25 pm
Ever since upgrading to 6.47.2 I have seen multiple wlan60-1 : link down/link up events in clients connected to my AP's. Here is what I have tried so far...
1) making sure every clients is aligned as well as possible.
2) upgrading OS AND Routerboard firmware to latest
3) changing frequencies
There are times where I think the problem is solved, but then it will start happening again. Does anyone know of a good way to limit the number of client disconnects? I have just been using the little plastic scope to align clients...perhaps there's a better (albeit much longer) way of correctly aligning clients?
My suspicion is that beamforming is the culprit behind the multiple disconnects, but I can find no reliable information anywhere in the forums about what causes this, and how to correct it. Any help would be appreciated.
StephenL
Re: wAP 60Gx3 clients keep disconnecting
Sat Sep 12, 2020 12:20 am
Once the clients are connected could you try locking the beam forming? I believe I remember seeing that option some where.
honzam
Sat Sep 12, 2020 10:44 am
Latest ROS and enable:
*) w60g - added "mdmg-fix" parameter for RBwAP60Gx3 (CLI only);
https://wiki.mikrotik.com/wiki/Manual:Interface/W60G
LAN, FTTx, Wireless. ISP operator
timmay2
Sun Sep 13, 2020 11:55 am
I pulled mine out of my network as they never worked reliably.
Was sad about it as I liked that headline that I could say it was a Gigabit link. I've had to replace with a Ubiquiti LTU sector. Either switch to the Wireless Wire 60deg sector AP or bin Wireless Wire all-together.
This reminds me I need to RMA my Wireless Wires...
Users browsing this forum: Baidu [Spider] and 49 guests
