fuerteapache
Netmetal ac2 Question
Thu Sep 24, 2020 10:05 pm
Hi guys!
I need to know if Two RP-SMA connectors in Netmetal ac2 are:
- One for 2.4Ghz - RP-SMA connector 0
- another for 5 Ghz - RP-SMA connector 1
am I right?
thanks in advanced
krafg
Re: Netmetal ac2 Question
Wed Sep 30, 2020 4:32 am
Both connectors support 2,4 and 5 Ghz at same time. It uses MIMO 2x2.
Regards.
helectro
Fri May 07, 2021 1:58 pm
I have a question to connect 2 dish antennas, one in 5ghz and the other in 2ghz, how do you connect it with only 2 rpsma connectors?
rextended
Fri May 07, 2021 3:18 pm
You must buy apposite antenna than support 5 and 2GHz at same time and same direction
krafg
Fri May 07, 2021 6:07 pm
Exactly, but I never saw dual band dish antennas but yes sector antennas.
https://www.l-com.com/wireless-antenna- ... or-antenna
Regards.
Users browsing this forum: grusu, Ralfu and 22 guests
