signa
wAP60x3
Tue Oct 13, 2020 2:16 pm
Seems as you can't get this working correctly, is it possible to disconnect the two side sector arrays and run it with a single as the wAP60G AP?
signa
Re: wAP60x3
Fri Oct 16, 2020 3:30 pm
@Mikrotik
honzam
Re: wAP60x3
Fri Oct 16, 2020 8:00 pm
try 6.48beta48. Now it works for us. But we have only 2 clients...
LAN, FTTx, Wireless. ISP operator
signa
Re: wAP60x3
Sun Oct 18, 2020 5:41 pm
Interesting, can you confirm you have a 60x3 AP? what are the link down counters showing since you installed beta48?
honzam
Re: wAP60x3
Sun Oct 18, 2020 6:24 pm
Yes, but only two clients on WAP60x3. 4 days uptime and no disconnect with beta48
signa
Re: wAP60x3
Sun Oct 18, 2020 6:31 pm
Do you know whether they're connected to the same internal sector? How far are they apart in the 180 arc?
honzam
Re: wAP60x3
Sun Oct 18, 2020 8:33 pm
74 and 97 meters. Situation:
signa
Re: wAP60x3
Sun Oct 18, 2020 9:04 pm
Hmm it's likely that it's on the same array, did you have lots of disconnections before?
Those signals look on the low side.
honzam
Re: wAP60x3
Sun Oct 18, 2020 9:09 pm
Yes, a lot of disconnections during the day. Maybe a few in an hour
initium
Re: wAP60x3
Mon Oct 19, 2020 12:58 pm
In short distance is lots of disconnection. Is not too visible not. Speed. but is clearly. impacting. Voice and Video conference where is necessary of QOS.
Users browsing this forum: No registered users and 38 guests
