wilsonfoz
Mikrotik hotspot issue - login page not loading
Wed Oct 14, 2020 10:37 pm
I've configured a hotspot on a Mikrotik CCR1036-12G (OS 6.47.4), but after the device connects to the wifi and asks to authenticate in the network, the login page remains loading for a while and returns an error page with net:ERR_CONNECTION_TIMED_OUT. The hotspot worked perfectly already, but suddently stopped.
wilsonfoz
Re: Mikrotik hotspot issue - login page not loading  [SOLVED]
Thu Oct 15, 2020 11:37 pm
Solved! The problem wasn't on Mikrotik configuration, that was OK. The problem was on the wifi configuration, in Unifi solution:
i) In the network configuration, the used network was marked as "Guest". I changed to "corporate".
ii) In the wireless configuration, there was enabled the "Gest Policy" option. I disabled it.
Both options (or maybe just one - the guest policy, I think) was resulting in the described problem because I didn't configure the guest portal in the Unifi solution. My fault... :´/
Well, we learn from our mistakes too...
Users browsing this forum: No registered users and 21 guests
