supreme72
netmetal ac2 +
Wed Oct 14, 2020 11:10 pm
Hello
I need to cover a shed 52m x 11m with wifi
I'd like to cover it in 5ghz but i'd prefer dual band
I've ethernet cables in the center(more or less) of the building.
I'd like to ask you if a single netmetal ac2 with 2 HGO-antenna-OUT can cover the entire building(≃20-30 meters).
I can place the netmetal so no wall is in the way and 3m of height. Near perimetral walls you can find metal machinery and metal sheets can be in the way on ground level(can they reflect waves and create noise?)
I need to connect 4-5 PCs (no big file trasfers) and 3-4 cameras . Low ping not needed.
I'd like the netmetal cause there is humidity and is metal case.
Thank you in advance for all the help you can give me!!!
supreme72
Re: netmetal ac2 +
Fri Oct 16, 2020 5:11 pm
help me plz :)
krafg
Long time Member
Long time Member
Re: netmetal ac2 +  [SOLVED]
Sat Oct 17, 2020 4:48 pm
Yes. You should not be problems.
Regards.
If you want to know my network, you can find it here.
supreme72
Re: netmetal ac2 +
Sat Oct 17, 2020 9:33 pm
Thank you!!!
Users browsing this forum: Baidu [Spider] and 35 guests
