Hello folks
I have simple PtP link
AP: DISC Lite5 ac
CPE: QRT 5 ac
Wireless protocol NV2 kinda works but slow, 802.11 gives better throughput, but does this:
Reply from 172.17.31.202: bytes=1450 time=3ms TTL=64
Reply from 172.17.31.202: bytes=1450 time=4ms TTL=64
Reply from 172.17.31.202: bytes=1450 time=5ms TTL=64
Reply from 172.17.31.202: bytes=1450 time=6ms TTL=64
Request timed out.
Request timed out.
Request timed out.
Reply from 172.17.31.202: bytes=1450 time=312ms TTL=64
Reply from 172.17.31.202: bytes=1450 time=33ms TTL=64
Reply from 172.17.31.202: bytes=1450 time=7ms TTL=64
Reply from 172.17.31.202: bytes=1450 time=11ms TTL=64
Request timed out.
Request timed out.
Request timed out.
Reply from 172.17.31.202: bytes=1450 time=10ms TTL=64
Request timed out.
Request timed out.
Request timed out.
Reply from 172.17.31.202: bytes=1450 time=448ms TTL=64
Reply from 172.17.31.202: bytes=1450 time=8ms TTL=64
Request timed out.
Request timed out.
Request timed out.
Reply from 172.17.31.202: bytes=1450 time=244ms TTL=64
Reply from 172.17.31.202: bytes=1450 time=13ms TTL=64
nv2 doesn't do this...
I have heard that there is incompatibility between mipsbe and arm hardware. Is this the case?
And what should I do for bettter performance:
Change AP to mipsbe?
Change CPE to arm?
I want to use vanilla 802.11, because it is more sophisticated for AC then nv2, true or not?
Thanks.
