Hi everyone,
I am facing a problem with my new Mikrotik kit and i really don't know what to do :( I am not a technical person and this situation is overwhelming for me.
So... I have a Huwaei B535 router, with a SIM card but the problem is that the signal s very poor where i live so i ordered a Mikrotik antenna that was recommended for my situation - LHG LTE6 kit.
I followe the instructions but i cannot connect to the internet and i don't know how to make an advanced configuration.
I tried to:
1) connect the antenna to the Huawei router via a cable - the SIM was in my router - didn't work
2) connect the antenna to the Huawei router via a cable - the SIM introduced in the antenna in the SIM slot - didn't work
3) connect the antenna to a TP-Link router via a cable - the SIM introduced in the antenna in the SIM slot - didn't work
4) connect the antenna directly to my laptop with the SIM introduced in the SIM slot - didn't work
I managed to create a password for the admin user, furthermore it recognizes the internet provider that i have, i was able to see those 2 graphics (RRIS or so).
It also connected to the internet when i used the 4th option, but the access is limited. Also, the option no 3 worked but the internet connection was limited - so i cannot access the internet.
Sorry for the ling post, but i am here for more than 5h and i really don't know what to do. If you can give me an advice would be more than appreciated!
Thank you!
