m94646602
Signal Range
Fri Nov 06, 2020 9:01 am
Signal Range in the CAPsMAN Access List means TX Signal or RX Signal or RSSI ?
karlisi
Re: Signal Range
Fri Nov 06, 2020 10:35 am
RX Signal
Karlis
m94646602
Re: Signal Range
Tue Dec 22, 2020 8:30 am
Does RX SIGNAL mean the signal strength from the client device(phone,notebook...) to the AP?
erlinden
Long time Member
Long time Member
Re: Signal Range
Tue Dec 22, 2020 8:44 am
It is the signal strength of the client, measured on the CAP.
Think here you can find some good (additional) information:
https://help.mikrotik.com/docs/display/ROS/CAPsMAN
First the problem, then the solution
Users browsing this forum: Baidu [Spider], Google [Bot] and 27 guests
