n21roadie
netPower Lite 7R - Reverse POE misunderstanding!
Tue Nov 17, 2020 2:56 pm
Just received a netPower Lite 7R and discovered that while several ether ports can have POE-IN but ONLY ether 8 has POE-OUT?
For a WISP having POE-Out is important along with POE on/off for POE ether ports, my plan was to replace RB960's having extra ether ports on the 7R but without POE-OUT
I must revise my plan ?
xvo
Re: netPower Lite 7R - What a Disappointment?
Tue Nov 17, 2020 3:32 pm
Looks like you missed that it is kind of special reverse-PoE switch.
For PoE-out there are different models.
MCN
Re: netPower Lite 7R - What a Disappointment? / NO WAY!!
Tue Mar 09, 2021 12:38 am
Yea you want something like the netPower 16P:
https://mikrotik.com/product/netpower_16p
Or a PowerBox Pro:
https://mikrotik.com/product/RB960PGS-PB
The netPower 16P has SFP+ and a bunch of POE out - so for a "wisp" that should be what ya need.
We look forward to using something like this in an MDU (multi dwelling unit) situation - one POE (out) to an antenna to pick up bandwidth, and reverse POE from each Customer.
That way if customers reboot their devices the switch and antenna stay up. You can add a battery back up to this if you want.
All in all a pretty slick unit.
normis
Tue Mar 09, 2021 10:18 am
Like the others said, this is a completely different device for a different purpose.
You should exchange this one for the netPower 16P
anav
n21roadie Literacy - What a Disappointment!
Tue Mar 09, 2021 10:14 pm
Suggesting the title of this thread is Very misleading and should be changed.
How bout.
n21roadie Literacy - What a Disappointment! ;-)
n21roadie
Re: n21roadie Literacy - What a Disappointment!
Wed Mar 10, 2021 2:46 pm
How bout.
"Literacy" - I don't know what " How bout." is ?
anav
Thu Mar 11, 2021 12:06 am
How bout.
Clearly slang homie,,,,,,,,,,, just axe me.
Besides, give a llama a break, my tongue is for licking fur not speaking!!!
PS - nutin wrong wid the gramma at the Latvian Website.
PSS Luv XVOs expression for this thread. Its a slight smirk, like you being a fool why did you go put your footin the mouth!
Users browsing this forum: phascogale and 68 guests
