volvox
SXT LTE6 kit - instable connection / lost internet
Mon Nov 23, 2020 10:18 pm
Hi all,
new user of forum and Mikrotik hardware, but have been lurking around and found a lot of useful info in Wiki and forum.
I just recently bought and installed an SXT LTE6 kit, I have it installed inside the house high up in the attic.
Distance from cellmast is 970 meters, terrain-profile shows I should have free line of sight, possibly with buildings and tree blocking slightly.
I have the unit mounted with centerline directly to tower, give or take a few degrees.
I know I would probably get a better signal if mounted outside, but I am unable to get to the ideal mounting posistion because it is so high up.
From monitoring signal strength I believe current location will do, with RSRP=-90dB, RSSI=-58dB, SINR=7dB.
The wall is an uninsulated wood wall, so shouldn't block too much signal.
With this signal I am able to get around 60Mbit/s down and 20Mbit/s up, which is sufficient for me (sometimes its better, sometimes worse).
I have upgraded RouterOS to latest 6.47.7 (stable), and was running at modem firmware R11e-LTE6_V025.
Notice yesterday that there was a new modem firmware R11e-LTE6_V026. Installed this new firmware, but it didn't seem to resolve the problem.
I am posting this because I have a problem in that my internet connection is not stable. I have noticed this all since I first installed it, but first thought I had it pointing wrong direction etc.
But I now wonder if there is a problem with hardware or firmware/software in my device.
I am located in Norway. My provider is Telenor, and I have the APN configured as telenor.smart.
I will give an example of what happens:
Yesterday night before I went to bed I had very good performance, about 55/19Mbit/s.
When I arrived home after work this afternoon I was unable to connect to internet.
I did a reboot of the device, and service was back up.
It then worked for an hour or two, before it stopped again.
I have previously noticed that I have had varying performance, where I seem to be moving between bands and cells.
So with info found on this forum and Seans forum at https://confusedbird.com/ I have tried to lock to a cell/band using at-chat commands.
I checked for a while before I decided Primary band B3@20Mhz seemed to give me best performance, with CA-band B8@10Mhz.
I accomplished thsi with the following command:
[admin@MikroTik] > /interface lte at-chat lte1 input="AT*Cell=2,3,,1450,3"
  output: +CREG: 6,"7b0d","01166b07",7
$CREG: 6,"7b0d","01166b07",7,"15c"
+CEREG: 1,"7b0d","01166b07",7
[admin@MikroTik] > /interface lte info lte1 once
           pin-status: ok
  registration-status: registered
        functionality: full
         manufacturer: "MikroTik"
                model: "R11e-LTE6"
             revision: R11e-LTE6_V026
     current-operator: 24201
                  lac: 31501
       current-cellid: 18246405
               enb-id: 71275
            sector-id: 5
           phy-cellid: 3
    access-technology: LTE (CA2)
         primary-band: B3@20Mhz earfcn: 1450 phy-cellid: 3
              ca-band: B8@10Mhz earfcn: 3750 phy-cellid: 93
                 rsrp: -90dBm
                 rsrq: -9.5dB
                 sinr: 3dB
Will continue in next post...
Edit: Added OS and firmware versions
volvox
Re: SXT LTE6 kit - instable connection / lost internet
Tue Nov 24, 2020 3:00 pm
When performance degrades or internet is lost, I notice I am no longer running with Primary Band + CA, only Primary.
And Access-technology has gone from LTE (CA2) to Evolved 3G (LTE):
           pin-status: ok
        functionality: full
                model: "R11e-LTE6"
                  lac: 31501
               enb-id: 71275
            sector-id: 5
           phy-cellid: 3
    access-technology: Evolved 3G (LTE)
       session-uptime: 3h13m25s
                 rssi: -60dBm
                 rsrp: -91dBm
                 rsrq: -9dB
                 sinr: 7dB
To fix this I would either reboot the device or run /interface lte at-chat lte1 input="AT*Cell=0"
Any advice on how to proceed in troubleshooting/fix this issue would be greatly appreciated!
Please let me know what more info I need to supply.
Best regards,
Jens
Update:
I have seen that peeople have been asked to supply cell-monitor informations, so here we go (after first unlocking with at-chat):
[admin@MikroTik] > /interface lte at-chat lte1 input="AT*Cell=0"
  output: +CREG: 6,"7b0d","01166b05",7
[admin@MikroTik] > /interface lte cell-monitor lte1
PHY-CELLID BAND                      PSC EARFCN                 RSRP          RSRQ          RSSI         SINR
       126 B3                                            1450                        -97dBm         -15dB
       128 B3                                            1450                        -93dBm         -10dB
       348 B7                                            3050                       -100dBm         -11dB
       349 B7                                            3050                        -99dBm       -15.5dB
       350 B7                                            3050                        -95dBm       -13.5dB
       373 B3                                            1450                       -105dBm       -19.5dB
[admin@MikroTik] > /interface lte cell-monitor lte1 duration=60
         5 B3                                              1450                      -104dBm       -19.5dB
        38 B3                                             1450                      -105dBm       -19.5dB
       126 B3                                            1450                        -95dBm       -13.5dB
       128 B3                                            1450                        -91dBm        -9.5dB
       194 B3                                            1450                        -97dBm       -19.5dB
There are some other cells showing up and disappearing, is there a way to keep everything it finds instead of blanking?
Jens
Update:
Checked today at lunch after leaving cell-selection open overnight.
Got good down/up-speed at 58.58/13.66Mbit/s and ping at 34ms. interface shows:
           pin-status: ok
        functionality: full
                model: "R11e-LTE6"
                  lac: 31501
       current-cellid: 18246412
               enb-id: 71275
            sector-id: 12
           phy-cellid: 221
       session-uptime: 14h23m29s
         primary-band: B7@20Mhz earfcn: 3248 phy-cellid: 221
              ca-band: B7@20Mhz earfcn: 3050 phy-cellid: 350
                 rssi: -70dBm
                 rsrp: -99dBm
                 rsrq: -6dB
                 sinr: 16dB
I have been connected this cell 18246412 before, but it has showed very varying performance, that is why I selected to try to bind to 18246405.
May have to take a step back and reassess, must admit I find it difficult to keep the head clear on what is happening... :)
Jens
Larsa
Tue Nov 24, 2020 8:04 pm
A bit odd that the signal strength (RSSI) is so high compared to SINR / RSRP which are far from optimal considering the proximity to the mast. This might indicate the unit is misaligned or there are objects like trees or buildings the dampers the signal.
B3 (1800Mhz) is a good choice but requires line-in-sight with no obstacle in between. Try to put the device at high as possible preferable on top of the roof using mast pipes. If you for some reason are unable to get a clear line-in-sight, pick the lower band B20 (800 Mhz) for a more stable signal.
When you have achieved a sufficiently stable signal, you can start adjusting specific options like carrier aggregation and cell lock.
Some useful hints regarding the various signal indicators: Mobile Signal Strength Recommendations
volvox
Tue Nov 24, 2020 8:53 pm
Thanks for taking the time, Larsa.
At least for now I don't have the option of moving higher up, and I have tried my best using maps and compass to get the alignment correct.
Buildings and trees are likely to be in the way, yes.
I had a look at the info in the link you supplied, and I have seen most of it before, but a very useful reminder.
When I installed/aligned, I paid most attention to RSRP and SINR, while at the same time trying to keep RSRQ in my sidevision :)
So to your suggestion:
I tried allowing only b20 (in webfig -lte1).
But result is not good, with DL of 4.86Mbps and UL slightly better at 12.91Mbps.
Here is the current info:
           pin-status: ok
        functionality: full
                model: "R11e-LTE6"
     current-operator: N Telenor
                  lac: 31501
       current-cellid: 18246400
               enb-id: 71275
            sector-id: 0
           phy-cellid: 27
       session-uptime: 1m27s
         primary-band: B20@10Mhz earfcn: 6400 phy-cellid: 27
                 rsrp: -80dBm
                 rsrq: -11dB
                 sinr: -2dB
                  cqi: 7
                   ri: 2
        52 B20                                                               6400        -90dBm       -19.5dB
       166 B20                                                               6400        -93dBm       -19.5dB
       321 B20                                                               6400        -86dBm         -18dB
       323 B20                                                               6400        -82dBm         -15dB
        29 B20                                                               6400        -95dBm       -16.5dB
        52 B20                                                               6400        -89dBm       -19.5dB
       166 B20                                                               6400        -94dBm       -19.5dB
       321 B20                                                               6400        -86dBm       -18.5dB
       323 B20                                                               6400        -83dBm       -13.5dB
As a test, should I try to lock to one of the other cells, or is that a waste of time?
Edit: Also: Shouldn't I be able to get CA2 on 800Mhz
volvox
Tue Nov 24, 2020 9:08 pm
I have 3 towers to choose from from my house.
I chose the current one because it was the closest. Its at 147degree bearing at a distance of about 970meters.
Drawback with this tower is that there is likely a lot of buildings and trees, as well as more people around it, being located in the village center.
The two other towers are further away, at about 2200 and 2300 meters (bearing north for one and north-west for the other one - roughly).
They are both located in areas of industry, so there are less people around them - particularly at night.
There are buildings of course, but I think terrain might help me a little.
My question:
Will the more than doubled distance to tower be neglible, so I should do further tests with those two other locations?
LineOfSight current location - with points being lifted up to real height above ground shows the line clear of terrain by 5-6meters.
But of course there are houses and trees that I am unable to calculate, but taller than that..
Larsa
Re: SXT LTE6 kit - instable connection / lost internet  [SOLVED]
Tue Nov 24, 2020 9:14 pm
It looks like the basic signal levels are still to low even for B20.
What do you get when testing with your smartphone? If you get a decent speed and good signal levels with your phone check what mast it's connected to by the Cell-ID and compare it with the device to check if its pointing to the same base station antenna.
About 2200 meters is still pretty close and no problem if you can manage to get a decent line-of-sight, that in this case is probably more important than the one which is closest.
What tower did your smartphone pick?
volvox
Tue Nov 24, 2020 9:37 pm
Thanks again.
From the living room two floors down it selects the same tower and cell as the mikrotik, at band 3, with similar poor performance Up/down.
I will do some LOS checks ( https://www.solwise.co.uk/wireless-elevationtool.html ) for the other to towers and see what they look like.
Then I will go up and move the Mikrotik to the "most promising one" and se what happens.
I have only tested it from the lower floors, so I guess moving up a few meters could be just enough to catch a sweet spot.
Larsa
Tue Nov 24, 2020 10:30 pm
Sounds good, feel free to come back and tell me how it went. Have a good one!
volvox
Tue Nov 24, 2020 10:34 pm
OK, went up to the loft and moved antenna to the other end of the house, pointing at a bearing of 357 degrees to the tower - distance 2.2km / elevation diff 14m.
At first it locked at b3@10Mhz as primary band and b3@20Mhz as CA, but after a speedtest of 62/43Mbps DL/UL with 42 ms ping it had switched the primary and CA - which makes sence performance-wise for the upload speed.
Here are some output:
           pin-status: ok
        functionality: full
                model: "R11e-LTE6"
                  lac: 31501
       current-cellid: 19127816
               enb-id: 74718
            sector-id: 8
           phy-cellid: 16
       session-uptime: 4m22s
         primary-band: B3@10Mhz earfcn: 1306 phy-cellid: 16
              ca-band: B3@20Mhz earfcn: 1450 phy-cellid: 373
                 rssi: -60dBm
                 rsrp: -85dBm
                 rsrq: -7.5dB
                 sinr: 16dB
        16 B3        1306        -95dBm          -6dB
        17 B3        1306        -110dBm       -19.5dB
        96 B3        1450        -103dBm       -11.5dB
       348 B7        3050        -124dBm         -16dB
       350 B7        3050        -124dBm         -16dB
       374 B3        1450        -102dBm       -19.5dB
           pin-status: ok
        functionality: full
                model: "R11e-LTE6"
                  lac: 31501
       current-cellid: 19127812
               enb-id: 74718
            sector-id: 4
           phy-cellid: 373
       session-uptime: 6m36s
         primary-band: B3@20Mhz earfcn: 1450 phy-cellid: 373
              ca-band: B3@10Mhz earfcn: 1306 phy-cellid: 16
                 rssi: -60dBm
                 rsrp: -89dBm
                 rsrq: -7.5dB
                 sinr: 16dB
[admin@MikroTik] >
There are no locks in place, except I only allow LTE. The unit was powered off during the move, so a fresh start..
Any comments?
Larsa
Tue Nov 24, 2020 11:52 pm
Looks like you nailed it at the initial "tryout"! Signal levels are significantly better and the ul-speed of 43 Mbit is actually very good.
At that speed, you should be able to get a ping latency of about 20-30 ms. Run a traceroute and pick the first available address that pops up and run a new ping test. You can also try to ping the gateway address in the lte1 interface (cmd: ip dhcp-client print detail). This will enable you to ping an address on the internal distribution network that causes a minimum delay.
Since this was the first attempt with the new placement, I would be very pleased. With a little further tweaking and fine tuning the location of the device, you can probably get another 10-15 Mbit on the inbound. But if you want to achieve significant greater improvements in speed than that, you need to establish a clear LoS by placing the antenna outdoors and without any visible obstacles to the tower.
volvox
Wed Nov 25, 2020 12:14 am
Larsa,
Yes, I’m quite happy with this. But I had done quite thorough preparations in finding the bearing to use.
I am calling it the night now, but will look into your suggestions tomorrow.
Might also try the tower to the nort-west, just for the fun of it...
Thanks,
Jens
SiB
Wed Nov 25, 2020 11:48 am
Please read that information:
Simple watchdog: viewtopic.php?f=7&t=153622&hilit=watchdog#p767767
Advance watchdog: viewtopic.php?f=9&t=151492&hilit=watchdog#p768392
LOG & Watch LTE parameters: viewtopic.php?f=7&t=155945&p=821262#p821047
MTCNA + MTCRE + MTCINE | ~600 users at ~150 RouterBoards in EMEA | Telegram: @SiB_PL
WinBox Tip: F6 works as ALT+TAB | Gliffy.com - free network schematic | prnt.sc - free ScreenShot software
I back from vacation and try answer at LTE posts
volvox
Wed Nov 25, 2020 2:52 pm
Thanks SIB,
I have seen those posts, and will investigate further.
But link currently seems much more stable, with Primary-band B3@20Mhz and CA-band b3@10Mhz giving down/up-speeds of 65/40.
Will investigate Larsas suggestion on improving/monitoring ping speeds, and get back when ready.
Jens
Edit: I have PRTG monitoring running, so I have some kind of historical data to help me when/if performance degrades.
volvox
Wed Nov 25, 2020 5:43 pm
Strange things are going on :)
I went up to turn the unit towards the tower in the northwest, just as a test to se what I would get.
So I turned unit to bearing 294degrees. (old bearing was 357degrees), and restarted the unit.
Then went down to check what was going on, how the signals would be.
And strangely enough it was still sitting at the tower/cell from yesterday.
I thought it might be because they were both withing the 60degree sector of the antenna, so I turned it further west to bearing approx 270degrees.
New reboot, but its still sitting comfortable on the same cell from the tower in the north:
           pin-status: ok
        functionality: full
                model: "R11e-LTE6"
                  lac: 31501
               enb-id: 74718
            sector-id: 4
           phy-cellid: 373
       session-uptime: 13m26s
                 rssi: -65dBm
                 rsrp: -94dBm
                 rsrq: -6.5dB
                 sinr: 14dB
As you can see, the signals are still quite good, even with that angle.And so are down/up speeds.
I am puzzled at what is going on.
I have tried to find position of towers based on cellid/lac etc. but I don't think the databases are updated.
Anyone have good source for locations? (In Norway we have something called www.finnsenderen.no , but it just shows location and owner, not the ID's .)
I am suspecting that when I thought I connected to the tower in the north yesterday, I actually connected to the tower in northwest.
I will try to point antenna to lets say bearing 30 to see if it changes.
volvox
Wed Nov 25, 2020 6:10 pm
OK, with unit pointing at bearing 30degrees it connected to a different cell:
           pin-status: ok
        functionality: full
                model: "R11e-LTE6"
                  lac: 31501
               enb-id: 74718
            sector-id: 8
           phy-cellid: 16
       session-uptime: 11m10s
                 rssi: -65dBm
                 rsrp: -93dBm
                 rsrq: -7.5dB
                 sinr: 24dB
                   ri: 2
It gives me 73Mbps down but only 9 down, with ping of 51ms.
So I try to lock on b3@20Mhz using
/interface lte at-chat lte1 input="AT*Cell=2,3,,1450,373"
This gives me:
           pin-status: ok
        functionality: full
                model: "R11e-LTE6"
                  lac: 31501
               enb-id: 74718
            sector-id: 4
           phy-cellid: 373
       session-uptime: 1m34s
                 rssi: -62dBm
                 rsrp: -90dBm
                 rsrq: -7dB
                 sinr: 16dB
And Down/Up of 86/22 with 43ms ping...
Hmm....
Guess I need to think a little about this, what is going on... :)
Edit: No that didn't look right, its back on current-cellid: 19127812 instead of current-cellid: 19127816
volvox
Wed Nov 25, 2020 7:51 pm
Larsa,
Here we go:
I didn't get your command ip dhcp-client print detail to give us what you asked for, instead I got:
admin@MikroTik] > ip dhcp-client print detail
But I did a traceroute in webfig - tools, and the first hop is 77.16.1.145.
Doing a ping to that gives me
25 of 25 packets received	0 % packet loss	Min: 32 ms	Avg: 38 ms	Max: 64 ms
I guess I can live with that, and consider mounting the antenna outside for improvement. That side of my house is much easier to get to using a lift.
To let the mind wander a little:
As i understand it, the SXT LTE6 Kit has a 9dBi antenna gain, with a beamwidth of 60degree.
There is a new unit announced - the LHGG LTE6 kit - sporting a 17dBi antenna gain with a beamwidth of 25degree.
I am not very familiar with signal-theory, so bear over with me....
If I were to get this new LHGG LTE6 unit, what improvement should I be expecting compared to my current unit?
Or does the improved antenna gain just come into play over longer distances and weaker signals?
It seems from the antenna gain patterns in the brochure that the new unit has better gain at both the two frequencies used here (800Mhz and 1800Mhz):
SXT LTE6:       1.5dBi@800Mhz and  7.4dBi@1800Mhz
LHGG LTE6:      4.8dBi@800Mhz and 15.2dBi@1800Mhz
And as for my test to the northwest today: Maybe that tower does not have sector covering me?
volvox
Wed Nov 25, 2020 8:00 pm
One of the tools I have used to get the bearings can be found here:
https://setcompass.com/
Might be useful for others as well....
mkx
Wed Nov 25, 2020 9:33 pm
The difference in gain is what you get regardless the distance to cell tower. If you're getting RSRP of -93dBm now, you'd get same cell at RSRP of around -85dBm. What changed antenna pattern does to interference depends where that interference comes from ... if it's from roughly direction towards cell tower, then RSRQ (or SINR, both measure ratio between signal and interference+noise) will remain the same. If, OTOH, interference source is in another direction, then using higher-gain antenna will improve RSRQ (and SINR).
Could be. Cell towers usually have high-gain antennae mounted and if none of them are directed in your direction, you won't receive signal from that cell tower.
BR,
Metod
volvox
Wed Nov 25, 2020 10:02 pm
Thanks, mkx.
And this is probably near to impossible to answer, but I have to ask:
How could the increase in RSRP from -93dBm to -85dBm in the B3 band (1800Mhz) translate into response time (ping) and down/up speeds, roughly ?
mkx
Wed Nov 25, 2020 11:21 pm
Ping time likely won't change (or not much). Change in UL/DL speeds will depend mainly on change in RSRQ/SINR. It will also depend on how MNO has QoS profiles set on cell tower. Ideally you could see double throughput, realistically 20-30% better, in (unlikely) worst case there won't be any change.
BR,
Metod
volvox
Wed Nov 25, 2020 11:59 pm
Nice! Thanks.
Does anyone know when LHGG lte6 kit will be generally available?
volvox
Thu Nov 26, 2020 12:03 am
I am marking this as solved by Larsa’s suggestion of obstructions in LOS causing the instability.
But feel free to come with further suggestions.
Thanks to Larsa, SiB and mkx for great contributions!
Jens
SiB
Thu Nov 26, 2020 8:37 pm
Yes, we have got in Poland MikroTik Distributors.
Larsa
Fri Nov 27, 2020 9:05 pm
Regarding the latency, it might be possible that your BTS was heavy loaded or you had payload traffic going on during the tests. I've checked some statistis for a number of links and most had around 20-30 ms (w/o payload). Live test of a 7 km link using B20:
Without payload:
$ ping xx.xx.xx.xx
PING xx.xx.xx.xx (xx.xx.xx.xx): 56 data bytes
64 bytes from xx.xx.xx.xx: icmp_seq=0 ttl=253 time=30.013 ms
64 bytes from xx.xx.xx.xx: icmp_seq=1 ttl=253 time=20.710 ms
64 bytes from xx.xx.xx.xx: icmp_seq=2 ttl=253 time=21.498 ms
64 bytes from xx.xx.xx.xx: icmp_seq=3 ttl=253 time=27.069 ms
64 bytes from xx.xx.xx.xx: icmp_seq=4 ttl=253 time=17.849 ms
64 bytes from xx.xx.xx.xx: icmp_seq=5 ttl=253 time=23.612 ms
64 bytes from xx.xx.xx.xx: icmp_seq=6 ttl=253 time=21.802 ms
64 bytes from xx.xx.xx.xx: icmp_seq=7 ttl=253 time=26.864 ms
64 bytes from xx.xx.xx.xx: icmp_seq=8 ttl=253 time=22.938 ms
64 bytes from xx.xx.xx.xx: icmp_seq=9 ttl=253 time=26.904 ms
64 bytes from xx.xx.xx.xx: icmp_seq=10 ttl=253 time=20.609 ms
64 bytes from xx.xx.xx.xx: icmp_seq=11 ttl=253 time=18.717 ms
64 bytes from xx.xx.xx.xx: icmp_seq=12 ttl=253 time=16.974 ms
64 bytes from xx.xx.xx.xx: icmp_seq=13 ttl=253 time=29.333 ms
--- xx.xx.xx.xx ping statistics ---
14 packets transmitted, 14 packets received, 0.0% packet loss
round-trip min/avg/max/stddev = 16.974/23.207/30.013/4.068 ms
With payload:
$ ping xx.xx.xx.xx
64 bytes from xx.xx.xx.xx: icmp_seq=0 ttl=253 time=37.586 ms
64 bytes from xx.xx.xx.xx: icmp_seq=1 ttl=253 time=95.906 ms
64 bytes from xx.xx.xx.xx: icmp_seq=2 ttl=253 time=37.614 ms
64 bytes from xx.xx.xx.xx: icmp_seq=3 ttl=253 time=69.963 ms
64 bytes from xx.xx.xx.xx: icmp_seq=4 ttl=253 time=124.013 ms
64 bytes from xx.xx.xx.xx: icmp_seq=5 ttl=253 time=56.237 ms
64 bytes from xx.xx.xx.xx: icmp_seq=6 ttl=253 time=146.011 ms
64 bytes from xx.xx.xx.xx: icmp_seq=7 ttl=253 time=124.132 ms
64 bytes from xx.xx.xx.xx: icmp_seq=8 ttl=253 time=312.794 ms
64 bytes from xx.xx.xx.xx: icmp_seq=9 ttl=253 time=106.108 ms
64 bytes from xx.xx.xx.xx: icmp_seq=10 ttl=253 time=23.792 ms
64 bytes from xx.xx.xx.xx: icmp_seq=11 ttl=253 time=83.974 ms
13 packets transmitted, 12 packets received, 7.7% packet loss
round-trip min/avg/max/stddev = 23.792/101.511/312.794/73.741 ms
Regarding the LHGG LTE6 kit ("RBLHGGR&R11e-LTE6"), it's available at a number of EU shops and ebay.
volvox
Fri Nov 27, 2020 9:43 pm
Larsa,
I think you are right, this is on a live network. And even if I don't have many devices connected, they may still contribute negatively to my testing, out of my control/knowledge.
I ran a similar test, first with relatively little "disturbance":
ping xx.xx.xx.xx size 64 count 10
SEQ HOST SIZE TTL TIME STATUS
0 xx.xx.xx.xx 64 63 30ms
1 xx.xx.xx.xx 64 63 34ms
2 xx.xx.xx.xx 64 63 28ms
3 xx.xx.xx.xx 64 63 34ms
4 xx.xx.xx.xx 64 63 28ms
5 xx.xx.xx.xx 64 63 34ms
6 xx.xx.xx.xx 64 63 28ms
7 xx.xx.xx.xx 64 63 34ms
8 xx.xx.xx.xx 64 63 28ms
9 xx.xx.xx.xx 64 63 34ms
sent=10 received=10 packet-loss=0% min-rtt=28ms avg-rtt=31ms max-rtt=34ms
Then did a test while at the same time running a speedtest.net test (55/33 down/up by the way).
ping xx.xx.xx.xx size 64 count 20
0 xx.xx.xx.xx 64 63 33ms
1 xx.xx.xx.xx 64 63 24ms
2 xx.xx.xx.xx 64 63 27ms
3 xx.xx.xx.xx 64 63 29ms
4 xx.xx.xx.xx 64 63 30ms
5 xx.xx.xx.xx 64 63 78ms
6 xx.xx.xx.xx 64 63 60ms
7 xx.xx.xx.xx 64 63 62ms
8 xx.xx.xx.xx 64 63 29ms
9 xx.xx.xx.xx 64 63 106ms
10 xx.xx.xx.xx 64 63 100ms
11 xx.xx.xx.xx 64 63 198ms
12 xx.xx.xx.xx 64 63 131ms
13 xx.xx.xx.xx 64 63 116ms
14 xx.xx.xx.xx 64 63 87ms
15 xx.xx.xx.xx 64 63 87ms
16 xx.xx.xx.xx 64 63 231ms
17 xx.xx.xx.xx 64 63 67ms
18 xx.xx.xx.xx 64 63 49ms
19 xx.xx.xx.xx 64 63 79ms
sent=20 received=20 packet-loss=0% min-rtt=24ms avg-rtt=81ms max-rtt=231ms
Didn't think the speedtest would do so much "harm" :)
As for the LHGG:
It was in stock at my suppliers distributor, it just wasn't in their webshop/product list at the time I checked.
Its ordered now, should get it over the weekend :) Looking forward to giving it a spin...
Edited for clarity...
volvox
Fri Nov 27, 2020 10:42 pm
So I guess I am about there...
Again - thanks!
SiB
Mon Nov 30, 2020 10:16 am
If you open the top-cover of LHGGR, please do a photo and share :)
And remember, Cell Monitor and Cell Lock are often greate way to right connection :)
volvox
Tue Dec 01, 2020 8:08 pm
Bad news from supplier, LHGG is not available from the distributor :(
No info on when it can be delivered...
Users browsing this forum: Baidu [Spider] and 90 guests
