m1m1
wpa_supplicant
Wed Dec 02, 2020 1:30 am
Heloo,
I get RaspberryPi 0 W, and wanted to set it up as headless.
Installed Raspbian and added conf and wpa_supplicant with name and pass of my network ( changed premade file ).
I cannot connect my Rpi on WiFi, they dont show on dhcp server. There is message in log:
"B8:27:EB:A4:63:F4@wlan1: connected, signal strength -53" and 5 seconds later "B8:27:EB:A4:63:F4@wlan1: disconnected, unicast key exchange timeout"
wpa_supplicant file:
ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev
update_config=1
country=US
network={
ssid="Mikrotik_Mikrotik"
psk="PASSWORD"
key_mgmt=WPA-PSK
In Security Profiles next is checked for pass: WPA PSK, WPA2 PSK. Unicast and Group chiper booth is aes ccm.
Wifi analyser on android says Im using: WPA2-PSK-CCMP
Is my wpa supplicant config wrong?
biomesh
Re: wpa_supplicant
Wed Dec 02, 2020 2:57 am
Can you try without the key_mgmt option?
m1m1
Re: wpa_supplicant
Thu Dec 03, 2020 12:19 am
Working confing ( may be usefoul to someone with same problem )
update_config=1
country=US
network={
ssid="Mikrotik"
psk="passwd"
key_mgmt=WPA-PSK
pairwise=CCMP
negge
Re: wpa_supplicant
Sat Dec 19, 2020 9:16 pm
Thanks for the working configuration! I was tearing my hair out with this exact same problem. Both "raspberry pi can't connect to wifi" and "unicast key exchange timeout" are essentially ungooglable problems, especially since this seems to be specific to the Raspberry PI W 0.
Users browsing this forum: No registered users and 27 guests
