sahar540
Outdoor straight line repeating
Mon Dec 07, 2020 4:31 pm
Hey everyone,
I would appreciate your advice on planning and getting the right hardware for this layout -
Some things that are important to me -
  1. All connections are wireless, no Ethernet cables
  2. Each device will connect to it's closest AP by naming the AP's 1/2/3/4....
  3. There might be more than these 4 station (maximum of 7)
Thanks!
anav
Re: Outdoor straight line repeating
Fri Dec 11, 2020 3:47 am
I dont understand your diagram at all.........
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
MTUNA Certified, by the Ascerbic Llama!
mistry7
Fri Dec 11, 2020 7:45 am
And more Information is needed what you want to do, how much Bandwidth is needed, why 75m between APs and only 2-3m to the client
Users browsing this forum: No registered users and 33 guests
