jmcguckin
Unstable 60G link
Tue Dec 08, 2020 5:02 am
This link is bouncing up/down every 15 minutes.
60G Cube Lite to WAP 60:
CPE side:
/interface w60g> monitor 0
connected: yes
frequency: 64800
remote-address: 04:D6:AA:69:97:B6
tx-mcs: 3
tx-phy-rate: 962.0Mbps
signal: 40
rssi: -58
tx-sector: 52
tx-sector-info: right 0.4 degrees, up 1.8 degrees
distance: 124.36m
tx-packet-error-rate: 4%
If you monitor for 30 seconds, you'll see the signal, rssi and tx-phy-rate values bounce around a bit. This is a clear line of sight with no obstructions on the roof of two buildings way above street level.
The CPE is
routerboard: yes
board-name: Cube Lite60
model: RBCube-60ad
serial-number: BF620B1C0175
firmware-type: qca9531L
factory-firmware: 6.45.8
current-firmware: 6.45.8
upgrade-firmware: 6.45.8
Base is
routerboard: yes
board-name: wAP 60G AP
model: RBwAPG-60ad-A
serial-number: 8B9408CBBC30
firmware-type: ipq4000L
factory-firmware: 3.40.1
current-firmware: 3.40.1
upgrade-firmware: 6.45.7
Any suggestions? Is there a preferred firmware?
Thanks!
server8
Re: Unstable 60G link
Tue Dec 08, 2020 6:09 pm
Latest ROS helps a lot
Users browsing this forum: No registered users and 51 guests
