illiniwireless
Where can I find the specs for R52H
Thu Jul 12, 2007 6:52 pm
I looked on routerboard.com and on mikrotik.com without success.
mipland
Re: Where can I find the specs for R52H
Fri Jul 13, 2007 11:43 am
Give a look on the upper right of this page (entire page), you will see a picture of the R52 mPCI card.
Click on it, you will be redirected to the shop section. You will see a "Description" button on the bottom of R52 (and R52H) section. Click on it and you will get the tech spec on PDF format.
Bye
dsobin
Sat Jul 14, 2007 7:55 am
I just clicked "Description" as suggested under the R52H and get
"Error 404: Not Found"
The target url is http://www.mikrotik.com/pdf/R52H.pdf
Bad link, perhaps?
The link for .../R52.pdf works fine.
mipland
Sat Jul 14, 2007 2:46 pm
Try the following:
R52
R52H
illiniwireless
Mon Jul 30, 2007 8:57 pm
Thanks for your reply .
Trisc
Wed Aug 01, 2007 8:31 pm
This document warns that the amplifier could be damaged if no antenna is connected. What is a safe TX power to use while testing on the bench? Its not always easy to attach antennas when you are just configuring the boards.
I assume if the card is disabled there is no risk to the amp circuits?
mipland
Thu Aug 02, 2007 9:45 am
Hy, the problem is the impedance which the amplifier seen.
If you want to test it on lab, attach it a little omni antenna (2dBi), or buy a dummy load at 50ohm.
When the card is disable, it transmit nothing, so no problem for the enclosed amp.
Users browsing this forum: Baidu [Spider] and 11 guests
