deweydb
Packetfence (RADIUS) + Hotspot + CAPsMAN + Dynamic VLAN
Mon Dec 14, 2020 10:57 pm
My goal is to setup a hotel wireless network where guests can roam across any AP in the building but remain in their dedicated room assigned VLAN. Additionally in each guest room there is a dedicated casting device connected to the TV. The goal is that the guest can cast media from their devices to this casting device. I have attempted to illustrate this with a small diagram. I apologize that my graphic design skills are not the greatest.
Note: at the moment I do not have the switch included I am only testing with a mikrotik router and access point. I am only showing this diagram as an example of the planned infrastructure, also the switch ports in the diagram are not necessarily correct i just drew some lines to indicate communication between devices.
I have configured an open wireless network, where guests are restricted from internet access initially behind a captive portal. I modified the mikrotik captive portal login.html file to redirect to the packetfence captive portal as outlined in the somewhat outdated packetfence mikrotik networking guide. I have CAPsMAN configured on the main router to manage the access points.
My problem is when my clients first connect they do not have an assigned VLAN tag. Once they complete authentication with the captive portal, Packetfence (RADIUS) replies with with Access Accept and
Mikrotik-Wireless-VlanID = <room_number>
Mikrotik-Wireless-VlanIDType = 0
In my CAPsMAN datapath configuration if I do:
/caps-man datapath
add bridge=bridge1 name=datapath1 vlan-mode=use-tag
the client is unable to connect to the wireless network, and does not receive an IP address.
If I leave out my datapath vlan configuration eg:
/caps-man datapath
The client connects, receives a hotspot pool ip, e.g. 10.5.50.123 and after authenticating with the captive portal, the client stays on 10.5.50.123, and becomes "Authenticated" in the hotspot. The packetfence logs show:
(10.2.2.1) Returning ACCEPT with VLAN 906
But the client does not switch to this VLAN.
Am I just going about this all wrong? It seems like I should have "use tag" enabled, but also have some sort of ACL that specifies the registration VLAN tag for unauthenticated users? Thank you for taking the time to read my post.
Here are my router config:
# dec/14/2020 20:28:41 by RouterOS 6.47.4
# software id = EVXY-A9Y7
# model = RouterBOARD 3011UiAS
# serial number = 8EEE0A390AAB
add mtu=1504 name=bridge1 protocol-mode=none
set [ find default-name=ether1 ] speed=100Mbps
set [ find default-name=ether2 ] speed=100Mbps
set [ find default-name=ether3 ] speed=100Mbps
set [ find default-name=ether4 ] speed=100Mbps
set [ find default-name=ether5 ] speed=100Mbps
set [ find default-name=ether6 ] speed=100Mbps
set [ find default-name=ether7 ] speed=100Mbps
set [ find default-name=ether8 ] speed=100Mbps
set [ find default-name=ether9 ] speed=100Mbps
set [ find default-name=ether10 ] speed=100Mbps
set [ find default-name=sfp1 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
/interface vlan
add interface=bridge1 mtu=1504 name="ether1-vlan 100 MGMT" vlan-id=100
add interface=ether1 name="ether1-vlan 103" vlan-id=103
add interface=bridge1 name="ether1-vlan 150 Phones" vlan-id=150
add interface=bridge1 name="ether1-vlan 200 CAST" vlan-id=200
add interface=bridge1 name="ether1-vlan 801" vlan-id=801
add interface=bridge1 name="ether1-vlan 905" vlan-id=905
add interface=bridge1 name="ether1-vlan 906" vlan-id=906
add interface=bridge1 name="ether1-vlan 907" vlan-id=907
add interface=bridge1 name="ether1-vlan 908" vlan-id=908
add interface=ether1 mtu=1504 name=ether1-vlan102 vlan-id=102
add interface=ether9 name="vlan35 for Bell" vlan-id=35
/caps-man datapath
add bridge=bridge1 name=datapath1 vlan-id=102 vlan-mode=use-tag
/interface pppoe-client
add add-default-route=yes disabled=no interface="vlan35 for Bell" name="Bell Fibe" password=<redacted> use-peer-dns=yes user=<redacted>
/caps-man security
add authentication-types="" name=GuestsNetwork
/caps-man configuration
add channel.band=2ghz-g/n channel.control-channel-width=20mhz channel.extension-channel=disabled channel.reselect-interval=1h datapath=\
    datapath1 multicast-helper=full name=GuestsNetwork2Ghz security=GuestsNetwork ssid=MikroTik
add channel.band=5ghz-n/ac channel.control-channel-width=20mhz channel.extension-channel=XX channel.reselect-interval=1d datapath=\
    datapath1 multicast-helper=full name=GuestNetwork5Ghz security=GuestsNetwork ssid=MikroTik
/ip hotspot profile
add dns-name=wifi.rookhotel.com hotspot-address=10.5.50.1 login-by=cookie,http-chap,https name=hsprof1 ssl-certificate=\
    CAPsMAN-744D2819AD41 use-radius=yes
add name="906 pool" ranges=10.9.6.8-10.9.6.14
add name=dhcp_pool1 ranges=10.5.5.2-10.5.5.254
add name="cast pool" ranges=10.4.4.2-10.4.4.254
add name="907 pool" ranges=10.9.7.8-10.9.7.14
add name="MGMT pool" ranges=10.2.2.50-10.2.2.60
add name="908 Pool" ranges=10.9.8.8-10.9.8.14
add name="102 VLAN dhcp" ranges=192.168.102.2-192.168.102.254
add name="905 Pool" ranges=10.9.5.8-10.9.5.14
add name="801 Pool" ranges=10.8.1.8-10.8.1.14
add name=hs-pool-27 ranges=10.5.50.2-10.5.50.254
add address-pool="906 pool" disabled=no interface="ether1-vlan 906" name="Room 906 DHCP"
add address-pool=dhcp_pool1 disabled=no interface="ether1-vlan 150 Phones" name=dhcp1
add address-pool="cast pool" disabled=no interface="ether1-vlan 200 CAST" name="cast dhcp"
add address-pool="907 pool" disabled=no interface="ether1-vlan 907" name="Room 907 DHCP"
add address-pool="MGMT pool" disabled=no interface="ether1-vlan 100 MGMT" name="MGMT DHCP"
add address-pool="908 Pool" disabled=no interface="ether1-vlan 908" name="Room 908 DHCP"
add address-pool="905 Pool" disabled=no interface="ether1-vlan 905" name="Room 905 DHCP"
add address-pool="801 Pool" interface="ether1-vlan 801" name="Room 801 DHCP"
add address-pool=hs-pool-27 disabled=no interface=bridge1 lease-time=1h name=dhcp2
/ip hotspot
add address-pool=hs-pool-27 disabled=no interface=bridge1 name=hotspot1 profile=hsprof1
/user group
set full policy=local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,password,web,sniff,sensitive,api,romon,dude,tikapp
/caps-man manager
set ca-certificate=auto certificate=auto enabled=yes
/caps-man manager interface
add disabled=no interface=bridge1
/caps-man provisioning
add action=create-dynamic-enabled comment=GuestNetwork2Ghz hw-supported-modes=gn master-configuration=GuestsNetwork2Ghz
add action=create-dynamic-enabled comment=GuestNetwork5Ghz hw-supported-modes=ac master-configuration=GuestNetwork5Ghz
/interface bridge filter
add action=drop chain=forward in-bridge=bridge1 out-bridge=bridge1
add bridge=bridge1 ingress-filtering=yes interface="ether1-vlan 100 MGMT" pvid=100
add bridge=bridge1 interface=eoip-tunnel1
add bridge=bridge1 interface=ether1 pvid=100
add bridge=bridge1 interface="ether1-vlan 906"
add address=10.9.6.1/28 interface="ether1-vlan 906" network=10.9.6.0
add address=10.2.2.1/24 interface="ether1-vlan 100 MGMT" network=10.2.2.0
add address=10.9.7.1/27 interface="ether1-vlan 907" network=10.9.7.0
add address=10.5.5.1/24 interface="ether1-vlan 150 Phones" network=10.5.5.0
add address=10.4.4.1/24 interface="ether1-vlan 200 CAST" network=10.4.4.0
add address=10.9.8.1/28 interface="ether1-vlan 908" network=10.9.8.0
add address=10.9.5.1/28 interface="ether1-vlan 905" network=10.9.5.0
add address=10.8.1.1/28 interface="ether1-vlan 801" network=10.8.1.0
add address=10.5.50.1/24 comment="hotspot network" interface=bridge1 network=10.5.50.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-relay
add dhcp-server=10.2.2.254 disabled=no interface="ether1-vlan 100 MGMT" name=packetfence
add address=10.2.2.0/24 gateway=10.2.2.1
add address=10.4.4.0/24 dns-server=8.8.8.8 gateway=10.4.4.1
add address=10.5.5.0/24 gateway=10.5.5.1
add address=10.5.50.0/24 comment="hotspot network" dns-server=8.8.8.8 gateway=10.5.50.1
add address=10.9.6.0/28 dns-server=8.8.8.8 gateway=10.9.6.1
add address=10.9.7.0/27 dns-server=8.8.8.8 gateway=10.9.7.1
add address=10.100.100.0/24 dns-server=8.8.8.8,8.8.4.4 gateway=10.100.100.1
set allow-remote-requests=yes servers=8.8.8.8
/ip dns static
add address=10.2.2.254 name=radius.<redacted>.com
add action=passthrough chain=unused-hs-chain comment="place hotspot rules here" disabled=yes
add action=drop chain=input in-interface="ether1-vlan 200 CAST" protocol=igmp
add action=accept chain=forward dst-address=10.2.2.0/24 src-address=10.0.2.0/24
add action=drop chain=forward disabled=yes dst-address=!10.0.0.0/8 src-address=10.2.2.0/24
add action=accept chain=forward src-address=10.2.2.254
add action=accept chain=forward disabled=yes dst-address=10.2.2.1 src-address=10.2.2.60
add action=masquerade chain=srcnat comment="NAT rule for 10.9.6.0/28" out-interface="Bell Fibe" src-address=10.9.6.0/28
add action=masquerade chain=srcnat comment="NAT rule for 10.9.7.0/27" out-interface="Bell Fibe" src-address=10.9.7.0/27
add action=masquerade chain=srcnat comment="NAT rule for Phones" out-interface="Bell Fibe" src-address=10.5.5.0/24
add action=masquerade chain=srcnat comment="NAT rule for MGMT network" out-interface="Bell Fibe" src-address=10.2.2.0/24
add action=masquerade chain=srcnat out-interface="Bell Fibe" src-address=10.4.4.0/24
add action=masquerade chain=srcnat comment="Test Rule" src-address=10.100.100.0/24
add action=masquerade chain=srcnat comment="masquerade hotspot network" src-address=10.5.50.0/24
/ip hotspot user
add name=admin
/ip hotspot walled-garden
add comment="place hotspot rules here" disabled=yes
add dst-host=10.2.2.254
add src-address=10.2.2.254
/ip hotspot walled-garden ip
add action=accept disabled=no dst-host=10.2.2.254
add action=accept disabled=no src-address=10.2.2.254
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
set www-ssl disabled=no
set api disabled=yes
set api-ssl disabled=yes
/ip ssh
set allow-none-crypto=yes forwarding-enabled=remote
/radius
add address=10.2.2.254 secret=<redacted> service=hotspot,wireless
/radius incoming
set accept=yes
/system clock
set time-zone-autodetect=no
/tool mac-server
here is my AP config:
# dec/14/2020 15:39:29 by RouterOS 6.47.8
# software id = WFU3-28AH
# model = RBcAPGi-5acD2nD
# serial number = B8BF0ABC78AF
add name=NewBridge
/interface wireless
# managed by CAPsMAN
# channel: 2422/20/gn(28dBm), SSID: MikroTik, CAPsMAN forwarding
set [ find default-name=wlan1 ] ssid=MikroTik
# channel: 5660/20-Ce/ac/DP(24dBm), SSID: MikroTik, CAPsMAN forwarding
set [ find default-name=wlan2 ] ssid=MikroTik
/ip hotspot profile
add bridge=NewBridge interface=ether1 pvid=100
add bridge=NewBridge interface=wlan2
add bridge=NewBridge interface=wlan1
/interface wireless cap
set certificate=request discovery-interfaces=NewBridge enabled=yes interfaces=wlan2,wlan1
/ip dhcp-client
add disabled=no interface=NewBridge
add action=accept chain=forward src-address=10.2.2.0/24
/radius
/radius incoming
set accept=yes
/system clock
set time-zone-name=America/New_York
/system identity
set name="Test CAP AC Mikrotik AP"
deweydb
Re: Packetfence (RADIUS) + Hotspot + CAPsMAN + Dynamic VLAN
Tue Jan 05, 2021 12:32 am
Bump
Users browsing this forum: No registered users and 36 guests
