I'm about to set up a short (50m) point to point link using two 5GHz SXT sq units.
Have done this before, but mainly over long distances (1-6 km) using the nv2 protocol. It works quite well. Not sure,however, if the nv2 protocol will give the best performance for this short distance, or if 802.11 may be a better choice. Any suggestions or recommendations?
-Olaf-
