gigatik
Output Power too high
Fri Jan 15, 2021 2:49 pm
i think i found a problematic bug with the country regulation and in combination with CAPsMAN.
If the setting no_country_set is used in CAPsMAN, i think the secure values of the CAPs are overwritten.
When using this setting the mean lifetime of severals wAP ac is about 6 months. In other posts on this forum i read, that the output power can not exceed the save level. How is this possible?
I think a wAP AC should only send with a max. power of 25dBm, when actually using no_contry_set it is 30dBm.
https://mikrotik.com/product/wap_ac
When setting the country regulation to a country and activating the option reselect intervall, the output was correct to regulations, but still too high for a wAP ac and it died now about a year after purchase.
mkx
Re: Output Power too high
Sat Jan 16, 2021 4:19 pm
I think you should communicate this directly with support@mikrotik.com ... probably they'll want supout files from both units (CAPsMAN manager and CAP device) to verify that CAP device is indeed transmitting at power higher than HW limit.
BR,
Metod
Users browsing this forum: Matta and 39 guests
