H3ronimous
hAP ac2 Google Home issue
Sat Jan 16, 2021 6:24 pm
I bought an hAP ac2 and enjoying it as "station mode" for wlan1 (I connected it to an existing public wifi) and as "ap bridge" for wlan2, so I'm generating my own ssid.
Everything is working and I'm really happy with that configuration except for 2 things:
-1 The most important, I have several devices including a Google Home. All the others devices working flawless but the Google Home has some issues that I can't figure out. It is able to connect and work for some hours but at some point, it just disconnect from Mikrotik and the only way to solve is to reboot the Google Home.
-2 I can't access Mikrotik control panel via wifi, I tried also via browser and WinBox and I can't connect to it. Otherwise, If I plug an ethernet cable between ac2 and a laptop, I can access only via winbox.
Any suggest?
H3ronimous
Re: hAP ac2 Google Home issue
Mon Jan 18, 2021 4:13 pm
up.
WeWiNet
Long time Member
Long time Member
Thu Jan 28, 2021 1:22 pm
Post config here:
in terminal
 export file=your-filename hide-sensitive
past it then in a post inside the [] code brackets for simpler readability
WeWiNet
MTCNA
I like a new challenge, I migrate to ROS7... :? no way, finally I stay with 6.48! I am NOT crazy :lol: !!!
bpwl
Thu Jan 28, 2021 2:30 pm
Double post entry? This one was solved ? viewtopic.php?f=13&t=171668
Users browsing this forum: No registered users and 43 guests
