alfred998
Can you have 2.4 and 5GHz on a single SSID with CAPsMAN ?
Tue Jan 19, 2021 3:51 pm
I have a RB750Gr3 running CAPsMAN and two cAP ac with a main and guest SSID. This is the configuration in CAPsMAN, but both SSID-s work on 2.4G only
/caps-man configuration
add datapath.bridge=guest-bridge mode=ap name=guest security.authentication-types=\
    wpa-psk,wpa2-psk security.passphrase=password ssid=guest
add datapath.bridge=wifi-bridge mode=ap name=main\
    security.authentication-types=wpa-psk,wpa2-psk security.passphrase=\
    password ssid=main
/caps-man manager
set enabled=yes
/caps-man manager interface
set [ find default=yes ] forbid=yes
add disabled=no interface=local-bridge
/caps-man provisioning
add action=create-dynamic-enabled master-configuration=main \
    slave-configurations=guest
add name=guest-pool ranges=10.10.10.2-10.10.10.254
add name=wifi-pool ranges=11.11.11.2-11.11.11.254
add address-pool=guest-pool disabled=no interface=guest-bridge lease-time=1h name=\
    guest-dhcp
add address-pool=wifi-pool disabled=no interface=wifi-bridge lease-time=3h name=\
    wifi-dhcp
add address=10.10.10.1/24 interface=guest-bridge network=10.10.10.0
add address=11.11.11.1/24 interface=wifi-bridge network=11.11.11.0
Do I need different SSID-s for 2.4 and 5G ?
mfrey
Re: Can you have 2.4 and 5GHz on a single SSID with CAPsMAN ?
Tue Jan 19, 2021 3:58 pm
For each SSID you need two configurations, one with 2.4 GHz and another one with 5GHz. Then you add both to your provisioning.
alfred998
Tue Jan 19, 2021 4:04 pm
I already have two configurations one main and one slave for guests. Do I need two more ?
ie SSID:
main 2.4
main 5
guest 2.4
guest 5
Or can I serve two configurations (2.4 and 5) in one SSID ?
mfrey
Tue Jan 19, 2021 10:56 pm
You need two configurations for each SSID, so a total of four in your case. And you can serve more than one configuration with the same SSID, as long as they are using different bands.
Users browsing this forum: Bing [Bot] and 37 guests
