nikola89381
Mikrotik LHG60 can be used 70.20 GHz frequency?
Fri Feb 05, 2021 12:41 pm
Hi Guys,
On this link I found this https://help.mikrotik.com/docs/display/ROS/W60G
Is it possible to use 70.20 GHz on LHG60 with the US region?
Thanks,
Regards Nikola
und3ath
Re: Mikrotik LHG60 can be used 70.20 GHz frequency
Sat Feb 06, 2021 3:28 pm
I have tried to add 69120 frequency into scan-list, but it did not stayed there.
According the mentioned table, 70200 Mhz - 1080 Mhz (half of 2160 MHz channel width) is 69120 MHz.
This applies to any other frequencies in the table, which are accepted in the scan-list.
nikola89381
Sat Feb 06, 2021 11:06 pm
I hope that Mikrotik will unlock more frequencies for LHG60, considering that the frequencies that are at 70 GHz have considerably less attenuation of radio waves in dB/km. And it is possible to achieve a more stable link at greater distances.
joegoldman
Long time Member
Long time Member
Sun Feb 07, 2021 1:32 am
The better frequencies are also generally reserved for licensed bands - not 'class license' or 'open' bands - as such the restrictions are based on local laws not on capabilities. Mikrotik could make a radio and antenna to run at any specific frequency they realistically wanted - but could risk being sued or banned from a region.
nikola89381
Re: Mikrotik LHG60 can be used 70.20 GHz frequency?
Mon Feb 08, 2021 5:36 pm
UBNT has a solution at 70 Ghz, so I thought that the mikrotik is moving in that direction :) It would be nice
ib254254
Sat Feb 20, 2021 10:40 am
I've asked this question to the support team before. the answers are;
Thank you for reaching to us.
Unfortunately there is no ETA for this feature or if it ever will be deployed.
Best regards,
Users browsing this forum: No registered users and 21 guests
