MyThoughts
60 GHz Oddities with Concerning Fix
Sun Feb 07, 2021 4:55 am
About two years ago we began testing 60 GHz equipment for PtMP deployments.
During out testing phase we settled on max distance of 300m for residential client deployments. Any further and we had too many drops (we see a fair amount of heavy rain in the summer and snow in the winter).
So these deployments were for client close to our tower locations, and in a roof top deployment in a suburban neighborhood.
This past year we have had quite a few odd issue, and as such we rarely upgrade the 60 GHz equipment as it has been prone to 'breaking' the connections.
In the rooftop deployment subdivision we are using a WAP60AP and LHG60 at the clients. We have had this location deployed since late spring with little issue running version .
This past Thursday night we had a reasonable snow fall with temps cold enough that the snow accumulated (3-5 inches).
In the morning of Friday the six clients connected to the WAP despite all indicating good alignment RSSI all low 50s. Basically nothing appearing different then the day they we installed the units were dropping continuously. The longest they would stay connected was a few minutes, with many dropping every 20-30s. Performance was all over the place, latency going between 0-timeout, massive tx-packet errors. The units when they dropped also took much longer to reconnect then usual.
The units and AP were all running 6.45.9, we proceeded to test all the channels available to us, we with some difficulty (they would rarely stay connected long enough to upload the new version) upgraded all the units and the AP to 6.48.1. The problem persisted on v6.48.1 we then attempted to lock the tx-sector in (disable beamforming) this did appear to improve things, but disconnects were still occurring to all clients every 3-5 minutes. We did a truck roll and replaced the AP unit, we had out techs brush snow off the roof where the AP was located (AP is ~6ft above peak), and brush snow off a couple of the clients roofs. There was no snow or ice build up on the AP or any of the LHGs. Still the problem persisted. The techs were about to begin swapping the LHG60 units to 5 GHz based equipment to get them back online.
Taking a shot in the dark I decided to downgrade the AP from 6.48.1 to various versions, all the versions had the exact same problem.
That was until I decided to try the oldest compatible version 6.44.6, and low and behold all the units connected instantly, MCS rates stabilized, latency was a solid <1ms and dropouts were not occurring.
We rebooted the AP a few times, and every time all the clients connected very fast, performance was great, and no dropouts.
It has been about 32 hours since the downgrade and I just double checked and we have not had a single one of the clients have a dropout.
All the clients are still running v6.48.1, but the AP is running v6.44.6.
I was glad I stumbled upon the solution, but the solution is concerning as all the other versions I attempted to use all had major dropout and tx error problems.
I just wanted to share this info with other in case it helps.
FYI: We have other deployments using the WAP60Gx3 AP and they had problems with individual clients dropping a lot that was fixed after we upgraded to v6.48 and also set the mdmg-fix=yes
I mention this as we have locations that are working and have problems that appeared to be resolved with v6.48.x and this rooftop location where anything other then v6.44.6 appears to be unusable.
vmnx
Re: 60 GHz Oddities with Concerning Fix
Wed Feb 10, 2021 9:48 pm
That is intresting.
So you are sugesting that snow is the reason for this?
I also having some issues with random ip connection problems (some client ip reachable, some not), but not sure is it related to RB version. I will try 6.44.6 on AP ant clients will upgrade to latest.
MyThoughts
Thu Feb 11, 2021 7:26 pm
Just a followup - I had another location running a wAP 60Gx3 with a single client approx distance 230m, similar problem (huge number of disconnects, 200-300+ per day).
This location however has the wAP mounted ~65 feet up on a tower and client side is ~23 feet up on top of the roof.
RSSI is -52 and during the problems the signal does not change.
I downgraded the wAP to v6.44.6 (client is still v6.48) a little over 48 hours ago, since the downgrade on the AP the client has not disconnected at all, and performance is very stable.
We have a couple other locations that I am watching. One is a wAP 60G with 4 business clients with distances from 300-500m. At this location the wAP is running v6.45.2 and we see the clients disconnect and reconnect on average 1-3 times per day. I am going to try downgrading the wAP to v6.44.6 as well and see if the disconnects also stop.
I had some thought that in the roof-top to roof-top setup that snow fall in the direct path could potentially cause reflections that would mess up the wAP's beamforming, causing the problems. I was speculating that the older version was using a different beamforming process/algorithm that was more stable in this scenario. But now I am unsure, and just want it working so if v6.44.6 works I will run that on the APs.
jonwang
Thu Feb 18, 2021 9:53 pm
Interesting. We've struggled with disconnects and finding a stable release. 6.48.x seemed to have solved a lot of our issues but I still see disconnects... like you mentioned some APs/CPEs just a few and others hundreds. Very interested if you downgrade the business client AP if you get the same behavior.
Users browsing this forum: No registered users and 51 guests
