ib254254
MİkroTik Wireless Gig+ Test
Thu Feb 11, 2021 11:29 pm
Gig+ Wireless test
equipment;
intel ax210 ( Wireless Kartı) Wi-Fi 6E
MikroTik RB4011iGS+5HacQ2HnD-IN (QCA9984) 802.11ac wave2
Maximum 1.1Gbit Wireless One Directional Speedtest.
good performance QCA9884, RouterOS Version 6.46.8
ib254254
Re: MİkroTik Wireless Gig+ Test
Thu Feb 11, 2021 11:31 pm
I wonder if MikroTik will provide Wi-Fi 6E support after how many years. When can it be ready for the technologies of the future?
nannou9
Fri Feb 12, 2021 1:24 am
This is same chip as audience.
Audience however has 4 chains for it.
I can’t get however more than 480mbit data transfer (with 1300mbit link, 3 chains 80mhz) as cpu seems to be limiting factor, where it uses fully 2 cores, while for some funny reason 2 others are unused.
Rb4011 ha much better cpu.
Can you check your cpu usage?
Most importantly if all cores are used or just two as in my case?
ib254254
Fri Feb 12, 2021 8:27 am
audionce will easily reach 1Gbps traffic in almost any scenario.
I don't think there is a problem with the CPU. Test conducted using Traffic Generator. The CPU generating to ip package bit high as they produce 4011.
ib254254
Are you sure you're connecting using 160mhz?
nannou9
Fri Feb 12, 2021 9:30 am
In your 1st post you have mentioned wave2, so I assumed you are using new beta 7.1b4 which uses wifiwave2 impl.
But from your other screenshot I can see you are on stable version.
My question was only regarding wifiwave2.
I am using it as it improves massively range and link stability. Otherwise audience with ros6 is worse than my 7 years old AirPort Extreme which I am looking to decommission- for the better rather than worse.
However under wifiwave2 I have this strange cpu issue which limits my bandwidth to about ~500mbit transfer, tested with iperf
WeWiNet
Long time Member
Long time Member
Fri Feb 12, 2021 7:04 pm
Hi ib254254
Interesting.
I tried RB4011 Wifiwave2 and Intel ac 9560 160Mhz client in Windows laptop.
For me speed is extremely disappointing! around 500Mbps (TCP iperf3 from separate laptop).
I saw similar speed on Audience and RB4011 with normal wifi package.
Interesting is that I see the same "PHY " rates than you, 1733mbps etc. but the final throughput is half of yours...!
Can you share the actual TCP speed you get on the client? I am kind of not trusting your Tx and Rx data rate numbers from within Winbox ;-)
WeWiNet
MTCNA
I like a new challenge, I migrate to ROS7... :? no way, finally I stay with 6.48! I am NOT crazy :lol: !!!
ib254254
Fri Feb 12, 2021 10:39 pm
nannou9
Thu Feb 18, 2021 8:55 pm
This is what I am getting too: max 500mb with iperf and it seems to use only half of the cores so might be some temporary beta limitation/bug I hope, which I hope they will fix soon.
The main reason why I am using wifiwave2 is because it has much better range and stability for mobile devices.
Rest I have wired using 10gig MikroTik switches.
When I saw your gig results I started to worry that this might be audience limitation, but if you get it with much more powerful rb4011, then it must be software.
anav
Thu Feb 18, 2021 9:59 pm
The reported result are bogus..............
1753/3 = 583Mpbs is what is more likely with direct LOS and no interfering obstacles.
At 1300/3 = 433Mbps speed can be expected.
Rough rule of thumb (take advertised two way speed, divide by two for one way and then subtract losses). 1/3 rule is a good starting number.
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
MTUNA Certified, by the Ascerbic Llama!
anuser
Long time Member
Long time Member
Thu Feb 18, 2021 10:46 pm
Intel AX200 connected at 1.2Gbit/s at Aruba AP-555 with 80 MHz channel == stable 800 Mbit/s up and down while copy a big file to and from a SMB file server.
pcunite
Thu Feb 18, 2021 11:02 pm
Tell the rest of the class what you paid for the Aruba.
anav
Thu Feb 18, 2021 11:58 pm
Hahah what a tard, anuser.......
https://www.cdw.com/product/hpe-aruba-a ... nt/5520246
Maximum data rate (2.4 GHz): 1.150 Mbps, Maximum data rate (5 GHz): 4.8 Gbps, Aggregate bandwidth: 5.95 Gbps
Thus using my rule of thumb, this unit should achieve one way throughput of 4.8/3 = 1.6Mbps plus minus. To be connecting at 1.2 and only getting 800 is a bit of a disappointment, you got robbed LOL.
If nothing else this demonstrates/proves, that the original poster is full of something that is not facts, and has an odour!
ib254254
Fri Feb 19, 2021 8:06 pm
seems like a devastating result for you.
If you review my MuM Presentation below you probably will elvis can leave the brain :)
https://mum.mikrotik.com/presentations/ ... 936230.pdf
CZFan
Location: South Africa, Krugersdorp (Home town of Brad Binder)
Fri Feb 19, 2021 9:52 pm
WoW, for that price, I will rather by 6 x RB4011s and place them all over where needed :-)
MTCNA, MTCTCE, MTCRE & MTCINE
Users browsing this forum: No registered users and 52 guests
