SWISSSNOW
HAMNET Germany
Sun Feb 14, 2021 6:35 pm
I'm using the IPQ4019 on RBD22UGS-5HPacD2HnD (mANTBox 52 15s) with v6.48.1 (same on board).
I like to use special frequencies licensed for HAMNET.
Mode: station bridge
Band: 5GHz A
Channel Width: 10MHz
Frequency: 5735
Frequency Mode: superchannel
Country: no_county_set
Installation: any
But I get the message: "Could't change Interface <wlan2> - bad band or frequency, see 'wireless info' for supported channels (6)"
Where do I get 'wireless info' - better question: How can I switch to 5735MHz with 10MHz bandwith ??
Greetings, Stefan
honzam
Re: HAMNET Germany
Sun Feb 14, 2021 7:50 pm
/interface wireless info allowed-channels
In regular rb922 your config works. So I think - it is limitation in IPQ4019 chipset maybe
LAN, FTTx, Wireless. ISP operator
mistry7
Re: HAMNET Germany
Sun Feb 14, 2021 9:59 pm
I remember that 10mhz channels wasn’t supported with ac Hardware..
SWISSSNOW
Re: HAMNET Germany
Mon Feb 15, 2021 10:07 am
Hi !
When I drop "/interface wireless info allowed-channels" on the CLI I get:
> /interface wireless info allowed-channels wlan1
channels:
> /interface wireless info allowed-channels wlan2
channels:
What's wrong ?
SWISSSNOW
Re: HAMNET Germany
Mon Feb 15, 2021 10:11 am
Ok. Would be nice to have a matrix with working channels und bandwith beside the RouterOS given options. It's a little confusing if options given in the CLI or GUI are leading to 'not working'.
Is there an official mikrotik moderator, that can drop a line to this? Thanks !!
WeWiNet
Long time Member
Long time Member
Re: HAMNET Germany
Mon Feb 15, 2021 12:21 pm
As already mentioned earlier here, Mikrotik 11ac products do not support anymore non Wifi standard channels (10Mhz or 5Mhz).
On the product page it is mentioned support 11a/n/ac, so why would the product offer something else?
But I don't know why you do not see "allowed-channels". On my IPQ 4019 device (Chateau) I get following.
Ssetup as AP with 802.11 as protocol, I assume you will need to select the appropriate (allowed) channel/functional mode first before seeing these.
/interface/wireless> info/allowed-channels wlan2
  channels: 5180/20-Ceee/ac/P(-7dBm),5185/20-Ceee/ac/DP(-10dBm),5190/20-Ceee/ac/DP(-10dBm),
            5195/20-Ceee/ac/DP(-10dBm),5200/20-Ceee/ac/DP(-10dBm),5205/20-Ceee/ac/DP(-10dBm),
            5210/20-Ceee/ac/DP(-10dBm),5215/20-Ceee/ac/DP(-10dBm),5220/20-Ceee/ac/DP(-10dBm),
            5225/20-Ceee/ac/DP(-10dBm),5230/20-Ceee/ac/DP(-10dBm),5235/20-Ceee/ac/DP(-10dBm),
            5240/20-Ceee/ac/DP(-10dBm),5245/20-Ceee/ac/DP(-10dBm),5250/20-Ceee/ac/DP(-10dBm),
            5255/20-Ceee/ac/DP(-10dBm),5180/20-Ceee/ac/DP(-10dBm),5185/20-Ceee/ac/DP(-10dBm),
            5190/20-Ceee/ac/DP(-10dBm),5195/20-Ceee/ac/DP(-10dBm),5200/20-Ceee/ac/DP(-10dBm),
            5205/20-Ceee/ac/DP(-10dBm),5210/20-Ceee/ac/DP(-10dBm),5215/20-Ceee/ac/DP(-10dBm),
            5220/20-Ceee/ac/DP(-10dBm),5225/20-Ceee/ac/DP(-10dBm),5230/20-Ceee/ac/DP(-10dBm),
            5235/20-Ceee/ac/DP(-10dBm),5240/20-Ceee/ac/DP(-10dBm),5245/20-Ceee/ac/DP(-10dBm),
            5250/20-Ceee/ac/DP(-10dBm),5255/20-Ceee/ac/DP(-10dBm),5260/20-Ceee/ac/DP(-10dBm),
            5260/20-Ceee/ac/DP(-10dBm),5500/20-Ceee/ac/DP(-3dBm),5505/20-Ceee/ac/DP(-3dBm),
            5510/20-Ceee/ac/DP(-3dBm),5515/20-Ceee/ac/DP(-3dBm),5520/20-Ceee/ac/DP(-3dBm),
            5525/20-Ceee/ac/DP(-3dBm),5530/20-Ceee/ac/DP(-3dBm),5535/20-Ceee/ac/DP(-3dBm),
            5540/20-Ceee/ac/DP(-3dBm),5545/20-Ceee/ac/DP(-3dBm),5550/20-Ceee/ac/DP(-3dBm),
            5555/20-Ceee/ac/DP(-3dBm),5560/20-Ceee/ac/DP(-3dBm),5565/20-Ceee/ac/DP(-3dBm),
            5570/20-Ceee/ac/DP(-3dBm),5575/20-Ceee/ac/DP(-3dBm),5580/20-Ceee/ac/DP(-3dBm),
            5585/20-Ceee/ac/DP(-3dBm),5590/20-Ceee/ac/DP(-3dBm),5595/20-Ceee/ac/DP(-3dBm),
            5600/20-Ceee/ac/DP(-3dBm),5605/20-Ceee/ac/DP(-3dBm),5610/20-Ceee/ac/DP(-3dBm),
            5615/20-Ceee/ac/DP(-3dBm),5620/20-Ceee/ac/DP(-3dBm),5625/20-Ceee/ac/DP(-3dBm),
            5630/20-Ceee/ac/DP(-3dBm),5635/20-Ceee/ac/DP(-3dBm),5640/20-Ceee/ac/DP(-3dBm)
WeWiNet
MTCNA
I like a new challenge, I migrate to ROS7... :? no way, finally I stay with 6.48! I am NOT crazy :lol: !!!
SWISSSNOW
Re: HAMNET Germany
Mon Feb 15, 2021 12:31 pm
Thanks for the information, I just was not around earlier here. Can't find a reason the GUI und CLI offers configuration parameters the hardware is not disigned for. Supporting 5/10MHz Bandwith beside any longer-higher-better "standard" could offer a professional usage for Log-Distance Connections. I choose one of the left-over old products ...
Users browsing this forum: No registered users and 38 guests
