KennyB
2.9.44 and 3.0.10beta association problem
Sat Jul 21, 2007 7:25 am
Hi all:
I have a very interesting problem. I have a test system set up with a 532a with sr9 and 2.9.38 as a ap-bridge on a tower. I have a client test that is a 532a in a rootenna with sr9 as station running 3.9.10beta. All works perfectly 2gh-5mhz channel.
Tonight I upgraded the tower only to 2.9.44 and the tower would not associate anymore with the client. I changed the configuration around where the tower was the station and the rootenna was the ap and I could associate again. Signals and thruput were the same as before upgrade.
I down graded to 2.9.43 and the same thing happened. Tower as ap and rootenna as client would not associate. Reversed them and all is good.
I downgraded back to 2.9.38 and everything worked as before. Tower as ap, rootenna as client perfect connection and performance.
anyone seen this before?????
Everything is set at default on both ends. SR9 cards. 532a boards on both ends.
Tomorrow I am going to walk up the 2.9 releases from 38 to see where it quits working.
any info would sure help.
Kenny
changeip
Re: 2.9.44 and 3.0.10beta association problem
Sun Jul 22, 2007 8:31 pm
I could never get 2.9.44 and 3.0b10 to associate... I think the same problem on 2.4.42 and even earlier. I think it has to do with the SR9s as well. I could get SR2 to associate but 10x retransmissions for every packet.
normis
Mon Jul 23, 2007 9:50 am
if you scan, do you see the other end? send us the supout.rif files from both ends
ivaring
Mon Jul 23, 2007 11:08 am
I've same problem.
I see other end from my antenna and viceversa, but WDS is not going up.
Maybe STP problem (with version 2.9.38) with newer versions of RouterOS...... :shock:
Users browsing this forum: modsx and 26 guests
