webparent1
How to create a virtual port or wlan
Sat Feb 20, 2021 3:05 pm
Hello, I am having a little problem on my mikrotik device. I just want to know how to create a virtual port on disc lite 5 cos it only have one port and I need another port to run a different service.
Below are the step.
1. Create a bridge
2. Create a virtual port and virtual wlan
Please take note that the ether1 and wlan had been used. I just need it to create a custom service and I just need to add another port since I am not allowed to use switch in this case.
Thank you.
Emmah
Rudolfs
Re: How to create a virtual port or wlan
Thu Feb 25, 2021 1:38 pm
You will not be able to create a virtual wlan interface as it is supported with license lvl4, but the Disc lite 5 comes with lvl3. You will need to upgrade your license if you want to implement those features:
https://wiki.mikrotik.com/wiki/Manual:L ... nse_Levels
anav
Thu Feb 25, 2021 5:44 pm
Is that license good for 24 hrs or one week.
Egads could I have a coffee please, sure.
Oh by the way this coffee needs sugar, oh thats extra $$............ ;-(
Since when do you nickel and dime on virtual wlans?
Either the radio is capable of it or it is not.
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
MTUNA Certified, by the Ascerbic Llama!
Users browsing this forum: Baidu [Spider] and 31 guests
