magos75
cAP to connect CAPSMAN layer3 instead layer2
Tue Mar 02, 2021 11:18 am
Hi!
It's my special problem when an electricity fault down/up my cAP (one of 2 cAPs) reconnect to my MT router (RB4011iGS) on layer3 instead layer2.
I noticed this issue when my mobile is lower speedtest but connection is 5Ghz - 433Mhz:
- Layer2 : 150-250Mbit
- Layer3 : 35-45Mbit
I don't understand...Why?
I have cAPs ether1 port on IP config because receive sntp time syncrhone from MT router. But 2 cAPs same config exclude ip address and managed from Router Capsman.
I have few VLAN and BRIDGE. But this issue just sometimes happens.
Any idea?
The goal: The cAPs connet to my MT Router CAPSMAN Layer2 EVERYTIME!
How to solve it?
Thanks for reply...
anav
Re: cAP to connect CAPSMAN layer3 instead layer2
Tue Mar 09, 2021 10:16 pm
Get rid of capsman until you can configure the router and capac properly without capsman.
Please include config of both.
genesispro
Fri Mar 12, 2021 10:27 am
well I guess removing the IP of the capsman and keeping only the interface would force it to connect only via Layer2
erlinden
Fri Mar 12, 2021 11:20 am
Can you please share both the configuration of the CAPsMAN and the CAP (and please post them between code tags):
CAPsMAN: /caps-man export
CAP: /export
gotsprings
Fri Mar 12, 2021 11:44 am
I need a wire diagram.
Users browsing this forum: McSee and 95 guests
