mishaKMS
Guest wifi without internet | Bridge mode | CAP AC
Sun Apr 25, 2021 4:28 pm
Hi there, can anyone tell me why there is no internet in guest wifi network? AP works in bridge mode, cable from router RB751U-2HnD connected to ether1. There is internet in main WLAN 2.4 GHz and 5 GHz, on ether2). When I created guest wifi with virtual interfaces - no internet on those SSID. My steps:
1) created virtual wifi interfaces in 2.4 GHz and 5 GHz (wlan2G , wlan5G)
2) created bridge "bridge-guest" for guest wifi
3) added two ports (interfaces wlan2G , wlan5G ) to bridge-guest
4) assigned ip adress to bridge-guest 10.1.1.1/24
5) configured DHCP-server for guest network
As a result clients gets ip-adresses but without internet connection.
I tried with quick set WISP AP, bridge mode, the same problem.
# jan/02/1970 02:21:45 by RouterOS 6.48.2
# software id = LDRA-7EJI
# model = RBcAPGi-5acD2nD
# serial number = DD340D558BE4
add name=bridge-guest
add name=bridge1
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-onlyn country=ukraine disabled=no \
    distance=indoors installation=indoor mode=ap-bridge name=wlan2G \
    preamble-mode=long ssid=miska_rada_2G station-roaming=enabled \
    wireless-protocol=802.11 wps-mode=disabled
add disabled=no keepalive-frames=disabled mac-address=hide \
    master-interface=wlan2G multicast-buffering=disabled name=wlan2g-guest \
    ssid=miska_rada_2G_free station-roaming=enabled wds-cost-range=0 \
    wds-default-cost=0 wps-mode=disabled
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
    20/40/80mhz-eeeC country=ukraine disabled=no frequency=auto installation=\
    indoor mode=ap-bridge name=wlan5G ssid=miska_rada_5G station-roaming=\
    enabled wireless-protocol=802.11 wps-mode=disabled
set [ find default=yes ] authentication-types=wpa2-psk eap-methods="" mode=\
    dynamic-keys supplicant-identity=MikroTik wpa2-pre-shared-key=hide
add eap-methods="" name=profile-guest supplicant-identity=""
/interface wireless
    master-interface=wlan5G multicast-buffering=disabled name=wlan5G-guest \
    security-profile=profile-guest ssid=miska_rada_5G_free station-roaming=\
    enabled wds-cost-range=0 wds-default-cost=0 wps-mode=disabled
add name=dhcp_pool0 ranges=10.1.1.2-10.1.1.254
add address-pool=dhcp_pool0 disabled=no interface=bridge-guest name=dhcp1
/user group
set full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,pas\
    sword,web,sniff,sensitive,api,romon,dude,tikapp"
add bridge=bridge1 interface=wlan2G
add bridge=bridge1 interface=wlan5G
add bridge=bridge-guest interface=wlan2g-guest
add bridge=bridge-guest interface=wlan5G-guest
add address=10.1.1.1/24 interface=bridge-guest network=10.1.1.0
add address=10.1.1.0/24 dns-none=yes gateway=10.1.1.1
anav
Re: Guest wifi without internet | Bridge mode | CAP AC
Mon Apr 26, 2021 8:00 pm
Duplicate post, follow it here....
viewtopic.php?f=2&t=174764
Users browsing this forum: Google [Bot], GoogleOther [Bot], martidim and 87 guests
