Buford
CAPSMAN and MULTIPLE VLANs are working but I can only see 1 ssid
Thu May 06, 2021 6:45 am
Hello there!
I work for a university here in the Philippines. We recently bought MikroTiks to upgrade our network (I am putting all of our Cisco devices out of commission).
I have successfully configured multiple VLANs and shared the internet to each VLAN by balancing 3 ISPs.
I have no problems with the wired part of our network.
I am having trouble with the WIFI though. I have followed all of the tips from the previous MUMs and have read the manual.
My problem is that I can only see 1 SSID on my laptop, I can't see the other 7...
And I can't connect to the network when I try...
I might have missed something and need a different set of eyes to look at my CAPSMAN configuration below.
Your help is greatly appreciated.
/caps-man datapath
add bridge=BACKBONE name=ICTO-datapath vlan-id=38 vlan-mode=use-tag
add bridge=BACKBONE name=ICTH-datapath vlan-id=56 vlan-mode=use-tag
add bridge=BACKBONE name=Employees-datapath vlan-id=64 vlan-mode=use-tag
add bridge=BACKBONE name=Students-datapath vlan-id=128 vlan-mode=use-tag
/caps-man security
add authentication-types=wpa2-psk disable-pmkid=yes encryption=aes-ccm group-encryption=aes-ccm group-key-update=1h group-key-update=1h name=wICTO_Security passphrase=***
add authentication-types=wpa2-psk disable-pmkid=yes encryption=aes-ccm group-encryption=aes-ccm group-key-update=1h name=ICTH_Security passphrase=***
add authentication-types=wpa2-psk disable-pmkid=yes encryption=aes-ccm group-encryption=aes-ccm group-key-update=1h name=Employees_Security passphrase=***
add authentication-types=wpa2-psk disable-pmkid=yes encryption=aes-ccm group-encryption=aes-ccm group-key-update=1h name=Students_Security passphrase=***
/caps-man channel
add band=2ghz-g/n control-channel-width=20mhz extension-channel=disabled frequency=2412 name=Chan1 tx-power=2
add band=2ghz-g/n control-channel-width=20mhz extension-channel=disabled frequency=2432 name=Chan6 tx-power=2
add band=2ghz-g/n control-channel-width=20mhz extension-channel=disabled frequency=2452 name=Chan11 tx-power=2
add band=2ghz-g/n control-channel-width=20mhz extension-channel=disabled frequency=2472 name=Chan13 tx-power=2
add band=5ghz-a/n/ac control-channel-width=20mhz extension-channel=disabled frequency=5180 name=Chan1_5G tx-power=12
add band=5ghz-a/n/ac control-channel-width=20mhz extension-channel=disabled frequency=5200 name=Chan2_5G tx-power=12
add band=5ghz-a/n/ac control-channel-width=20mhz extension-channel=disabled frequency=5220 name=Chan3_5G tx-power=12
add band=5ghz-a/n/ac control-channel-width=20mhz extension-channel=disabled frequency=5240 name=Chan4_5G tx-power=12
/caps-man rates
add name="802.11g/n Only" basic=6Mbps supported=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps
/caps-man configuration
add channel=Chan1 country=philippines rates="802.11g/n Only" datapath=ICTO-datapath distance=indoors installation=indoor mode=ap name=ICTO_Config security=wICTO_Security ssid=ICTO
add channel=Chan6 country=philippines rates="802.11g/n Only" datapath=ICTH-datapath distance=indoors installation=indoor mode=ap name=ICTH_Config security=ICTH_Security ssid=ICTH
add channel=Chan11 country=philippines rates="802.11g/n Only" datapath=Employees-datapath distance=indoors installation=indoor mode=ap name=Employees_Config security=Employees_Security ssid=Employees
add channel=Chan13 country=philippines rates="802.11g/n Only" datapath=Students-datapath distance=indoors installation=indoor mode=ap name=Students_Config security=Students_Security ssid=Students
add channel=Chan1_5G country=philippines datapath=ICTH-datapath distance=indoors installation=indoor mode=ap name=ICTH5G_Config security=ICTH_Security ssid=ICTH-5G
add channel=Chan2_5G country=philippines datapath=ICTO-datapath distance=indoors installation=indoor mode=ap name=ICTO5G_Config security=wICTO_Security ssid=ICTO-5G
add channel=Chan3_5G country=philippines datapath=Employees-datapath distance=indoors installation=indoor mode=ap name=Employees5G_Config security=Employees_Security ssid=Employees-5G
add channel=Chan4_5G country=philippines datapath=Students-datapath distance=indoors installation=indoor mode=ap name=Students5G_Config security=Students_Security ssid=Students-5G
/caps-man provisioning
add action=create-enabled comment="802.11g Capable Clients" hw-supported-modes=g master-configuration=ICTO_Config slave-configurations=ICTH_Config,Employees_Config,Students_Config name-format=prefix-identity name-prefix="2.4GHz-"
add action=create-enabled comment="802.11ac Capable Clients" hw-supported-modes=ac master-configuration=ICTO5G_Config slave-configurations=ICTH5G_Config,Employees5G_Config,Students5G_Config name-format=prefix-identity name-prefix="5GHz-"
/caps-man manager
set ca-certificate=auto certificate=auto enabled=yes
erlinden
Forum Veteran
Forum Veteran
Re: CAPSMAN and MULTIPLE VLANs are working but I can only see 1 ssid
Thu May 06, 2021 8:48 am
First thing I see is that you are trying to assign a different channel to a slave config. That might be the issue as there is only one radio to be configured (on the master configuration). Can you try to remove anything radio-wise on the slave configs?
First the problem, then the solution
Buford
Thu May 06, 2021 10:40 am
Thank you for replying.
Did you mean like this?
/caps-man channel
add band=2ghz-g/n control-channel-width=20mhz extension-channel=disabled frequency=2412,2432,2452,2472 name=2.4GHz tx-power=2
add band=5ghz-a/n/ac control-channel-width=20mhz extension-channel=Ce frequency=5180,5200,5220,5240 name=5GHz tx-power=12
add channel=2.4GHz country=philippines datapath=ICTO-datapath distance=indoors installation=indoor mode=ap name=ICTO_Config security=wICTO_Security ssid=ICTO
add channel=2.4GHz country=philippines datapath=ICTH-datapath distance=indoors installation=indoor mode=ap name=ICTH_Config security=ICTH_Security ssid=ICTH
add channel=2.4GHz country=philippines datapath=Employees-datapath distance=indoors installation=indoor mode=ap name=Employees_Config security=Employees_Security ssid=Employees
add channel=2.4GHz country=philippines datapath=Students-datapath distance=indoors installation=indoor mode=ap name=Students_Config security=Students_Security ssid=Students
add channel=5GHz country=philippines datapath=ICTO-datapath distance=indoors installation=indoor mode=ap name=ICTO5G_Config security=wICTO_Security ssid=ICTO-5G
add channel=5GHz country=philippines datapath=ICTH-datapath distance=indoors installation=indoor mode=ap name=ICTH5G_Config security=ICTH_Security ssid=ICTH-5G
add channel=5GHz country=philippines datapath=Employees-datapath distance=indoors installation=indoor mode=ap name=Employees5G_Config security=Employees_Security ssid=Employees-5G
add channel=5GHz country=philippines datapath=Students-datapath distance=indoors installation=indoor mode=ap name=Students5G_Config security=Students_Security ssid=Students-5G
Mistakes are steps to Knowledge
erlinden
Forum Veteran
Forum Veteran
Thu May 06, 2021 10:53 am
Only select a channel on a master, on any slave you can leave channel empty (as it is already defined on the master). Per accesspoint per radio you can have only one channel selected (from a list).
Buford
Thu May 06, 2021 11:13 am
I am currently doing a trial and error addition of lines starting from zero.
So far, I can now see all of the 2.4GHz SSIDs.
My problem is now activating the 5GHz SSIDs.
I will post my revisions when I am able to get everything up and running.
Buford
Thu May 06, 2021 11:15 am
Hello erlinden,
I will also try omitting the channel part on the config.
Sorry, I did not see you 2nd reply before I posted mine.
Since, it is easier, I will do your suggestion first.
Buford
Thu May 06, 2021 11:26 am
Hello erlinden,
sad to say but omitting the channel did not help...
erlinden
Forum Veteran
Forum Veteran
Thu May 06, 2021 12:22 pm
Do you mean on both radio's or on the 5G radio?
In case of the latter, just copy the working configs.
You might want to update your /caps-man export (or add a new one)
Buford
Thu May 06, 2021 1:35 pm
Sorry for the late reply, I just got home from work.
It's on both radios.
Buford
Fri May 07, 2021 5:15 am
Hello erlinden!
Below is my latest config. At this time, I am now able to see and successfully connect to all the 2.4GHz SSIDs. The 5GHz radio is still inactive though.
/caps-man datapath
add bridge=BACKBONE name=ICTHall-datapath vlan-id=56 vlan-mode=use-tag
/caps-man security
add authentication-types=wpa2-psk encryption=aes-ccm group-encryption=aes-ccm name=ICTO_Security passphrase=***
add authentication-types=wpa2-psk encryption=aes-ccm group-encryption=aes-ccm name=ICTHall_Security passphrase=***
add authentication-types=wpa2-psk encryption=aes-ccm group-encryption=aes-ccm name=Employees_Security passphrase=***
add authentication-types=wpa2-psk encryption=aes-ccm group-encryption=aes-ccm name=Students_Security passphrase=***
/caps-man channel
add band=2ghz-b/g/n control-channel-width=20mhz frequency=2412,2432,2452,2472 name=2.4GHz tx-power=5
add band=5ghz-a/n/ac control-channel-width=20mhz frequency=5180,5200,5220,5240,5260,5280 name=5GHz tx-power=15
/caps-man rates
add channel=2.4GHz country=philippines rates="802.11g/n Only" datapath=ICTO-datapath distance=indoors installation=indoor mode=ap name=ICTO_Config security=ICTO_Security ssid=ICTO
add channel=2.4GHz country=philippines rates="802.11g/n Only" datapath=ICTHall-datapath distance=indoors installation=indoor mode=ap name=ICTHall_Config security=ICTHall_Security ssid=ICTHall
add channel=2.4GHz country=philippines rates="802.11g/n Only" datapath=Employees-datapath distance=indoors installation=indoor mode=ap name=Employees_Config security=Employees_Security ssid=Employees
add channel=2.4GHz country=philippines rates="802.11g/n Only" datapath=Students-datapath distance=indoors installation=indoor mode=ap name=Students_Config security=Students_Security ssid=Students
add channel=5GHz country=philippines datapath=ICTO-datapath distance=indoors installation=indoor mode=ap name=ICTO5G_Config security=ICTO_Security ssid=ICTO-5G
add channel=5GHz country=philippines datapath=ICTHall-datapath distance=indoors installation=indoor mode=ap name=ICTHall5G_Config security=ICTHall_Security ssid=ICTHall-5G
add action=create-dynamic-enabled master-configuration=ICTO_Config slave-configurations=ICTHall_Config,Employees_Config,Students_Config
add action=create-dynamic-enabled master-configuration=ICTO5G_Config slave-configurations=ICTHall5G_Config,Employees5G_Config,Students5G_Config
/caps-man manager
Buford
Fri May 07, 2021 6:35 am
The 5GHz SSIDs are now visible. Strangely, I could not connect to the network through 5G...
Buford
[SOLVED] Re: CAPSMAN and MULTIPLE VLANs are working but I can only see 1 ssid  [SOLVED]
Mon May 10, 2021 5:55 am
I was able to solve the problem by doing the following:
1. Upgrade all my RouterOS versions from the long-term support version 47.9 to the latest stable 48.2
2. Edit my caps-man provisioning to the following:
add action=create-dynamic-enabled hw-supported-modes=gn master-configuration= ICTO_Config name-format=prefix-identity name-prefix=2.4GHz- slave-configurations=Employees_Config,Students_Config
add action=create-dynamic-enabled hw-supported-modes=ac master-configuration=ICTO5G_Config name-format=prefix-identity name-prefix=5GHz- slave-configurations=Students5G_Config,Employees5G_Config
Strangely using action=create-enabled did not work for my setup.
I hope this helps others.
My next problem is that both radios constantly drop. But that will be on another post.
Thanks erlinden!
Users browsing this forum: uxer and 84 guests
