MUM Europe 2020
InoX
1.5km link 108mbps
Fri Aug 03, 2007 9:23 pm
If I make a bridge with 2 MT and 2x108mbps cards, 24dBi antennas, LOS, will I get 6-7MB/s? Whats the max. speed with 2x108mbps cards?
Thanks!
mneumark
Re: 1.5km link 108mbps
Sat Aug 04, 2007 8:20 am
Thanks!
Should be able to get that with no problems. I have links that are further then that and they get 13MB+ with WDS one way.
unlimitedme
Mon Aug 06, 2007 1:07 pm
In theory,
if you bond those 2 physical interface, you will get about +40MB,
but in reality, it will drop to 50%,
try to use Nstreme2, maybe you will get better performance
valens
Trainer
Trainer
Mon Aug 06, 2007 7:41 pm
is it 8 MegaByte/second, or 8 megabit / second?
for 8 megabit/second... it's not hard to reach with Mikrotik.
But for 8 MegaByte/second.... you need to be perfect and ideal.
jo2jo
Forum Veteran
Forum Veteran
Mon Aug 06, 2007 8:23 pm
you dont need 24db antennas, and if you only need 8-10 mbit then you can use R52s and RB 133s go with the level 4 OS ones.
this should be a easy link
InoX
Fri Aug 10, 2007 12:07 am
6MB/s means 48mbps...some might use an online unit converter :lol:
I ask again...is it posible that if I use 2x108mbps cards and 2x24dBi antennas to reach ~48mbps at 1.5km link?
And is nstreme not nstreme2...one card at each bridge.
Thanks.
mcozio
Fri Aug 10, 2007 12:31 pm
nstreme-dual, 2x core2duo, 4x wmia123ag = 70-80mbps both way, 5gturbo
if add one more card each side we can get over 100-110mbps
boardman
Tue Aug 14, 2007 4:36 am
Hi there, how are you "bonding" and powering those wmia123ag's ?
Best
Jorge
mcozio
Thu Aug 16, 2007 4:26 pm
well, I tried this - ns2 and bonding 2x2 to compare
http://wiki.mikrotik.biz/wiki/index.php ... Bonding%22
It is taken from manual
and you should read this
http://wiki.mikrotik.com/wiki/Super_wireless_test
In one word: with a pipe built with 2-3-4 mt oraz cards each side you can easy add/remove one or two and won't lost a link, with ns2 it is very risky, beacouse ns2-mac changes each time you put a new card.
Users browsing this forum: No registered users and 36 guests
